Hello
I am making tcp client/server and for now I can read the incoming packages over tcp but I can not send any messages.
#include <SPI.h>
#include <UIPEthernet.h>
String serial_data;
char incomingByte = 0;
char s = 0;
int choice = 0;
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress server(10, 5, 5, 10); // numeric IP for Google (no DNS)
IPAddress ip(10, 5, 5, 106);
EthernetClient client;
// start the Ethernet connection:
Ethernet.begin(mac, ip);
// give the Ethernet shield a second to initialize:
Serial.println("connecting...");
// if you get a connection, report back via serial:
if (client.connect(server, 9876)) {
Serial.println("connected");
else {
// if you didn't get a connection to the server:
Serial.println("connection failed");
Serial.println("Wcisnij a aby odczytywac pakiety");
Serial.println("Wcisnij b aby wysylac pakiety");
Ethernet.maintain();
// Read serial input:
if (Serial.available() > 0)
incomingByte = Serial.read();
switch (incomingByte) {
case 'a':
//Serial.print("Logi");
if (client.available()) {
char c = client.read();
Serial.print(c);
Serial.print("");
if (!client.connected()) {
client.connect(server, 9876);
case 'b':
//Serial.print("Wpisz komendę");
if (Serial.available() > 0) {
Serial.println("Sent..");
serial_data = String(Serial.read());
client.print(serial_data);
#include <SPI.h>
String serial_data;
char s = 0;
int choice = 0;
else {
case 'a':
Serial.print(c);
Serial.print("");
case 'b':
For now the choosing option is working
i press a - i read from server
i press b i jump to "b" case
BUT i don't know how to properly send soem packages to the server
I don't know what you want to do. your code receives one character if 'a' is sent from Serial Monitor and sends one character if 'b' is sent from Serial Monitor.
you could replace if (Serial.available()) with while (Serial.available()) to send more then one character after b. but I guess even then it would not send everything because of gaps between characters sent from Serial Monitor
while (Serial.available() > 0) {
char inChar = Serial.read();
if (client.connected()) {
client.print(inChar);
so it looks just like my code...
Tried it anyway it does not work.
I use TCPIPbuilder app to listen on that port and when i send packets from the server (fq2 camera) it appears both in this app and in my serial (when i choose "a")
But if I type in my command "b case" nothing appears in TCPIPbuilder so I guess i do not send anything...
Okay let's take it easier.
Let's make JUST sending option (if it works i will add it to the main program).
code:
#include <SPI.h>
//#include "packet.h"
String serial_data;
char s = 0;
int choice = 0;
else {
Serial.println("Type command");
client.write(inChar);
Serial.println("Sent");
And below i will put a screenshot in which you see that if i send packages from my server (smart camera) the logs appear there BUT as you can see my program went through ("Sent package" and "Sent" is a confirmation and nothing appears
I tired everything one letter, one number words, numbers evberything. nothing works. I think i must send it in other way, like a "package" with specific length etc but that's just my idea i do not know how to do it
