system
September 27, 2014, 9:20am
1
Hi
I am newbie in Arduino,
I want make color identifier with TCS230. ? was download in
https://arduinocode.codeplex.com/releases/view/115253 library .when I was load to Arduino Uno in serial Monitor all line write
RGB:255,255,255 for all colour.
Anyone read correct RGB values like this project also I don't know Sensor's pin to Arduino Pin numbers in this project
UPDATE :? was read in zip file pdf documents and not have any pin connections details ..
I am waiting your help
Regards
welcome to Arduino land
did you search the forum already for clues? like - http://forum.arduino.cc/index.php/topic,118967.0.html -
system
September 27, 2014, 10:03am
3
Thank You @robtilaart
Thanks for link too,
I understand for Correct connection of TCS230
Sensor -> Arduino UNO
pin OUT -> pin 2
pin S2 -> pin 3
pin S3 -> pin 4
But I don't understand sensor's other side pin connections
( OE,S1,S0)
Also sensor's leds not on while connect VCC and GND (5 volt) is that normal ?
I think S0 and S1 for frequency range choise (%2,%50 and %100)
and OE to GND
or am I wrong?
system
September 27, 2014, 10:14am
4
Hi Serhat,
please find hereby my last topic:
http://forum.arduino.cc/index.php?topic=268903.0
marco_c have already discussed about connections and settings.
Hope this will help.
system
September 27, 2014, 11:02am
5
Thanks for link
I am new in Arduino but I know Proton basic so I must make that project I have not so much time
Anyway I had correct worked for 3 color .so sensor have not any hardware problem
if I know RGB algoritms I can write all codes
have not any person say to me :
"Use in here link program ....and all 8 pin's connections is that
system
September 27, 2014, 12:14pm
6
Finally Read correct RGB values
have a choise in arduino IDE software which last loaded file load
I mean I want learn which file loaded ,when I open IDE it must be automatic load source codes too
Have any choise for this in menus?
