TCS3200 Color sensor + button ?
I have a Arduino Uno and a TCS3200 Color-sensor and have been trying it out with this code:
int s0=3,s1=4,s2=5,s3=6;
int out=2;
int flag=0;
byte counter=0;
byte countR=0,countG=0,countB=0;
 pinMode(s0,OUTPUT);
 pinMode(s1,OUTPUT);
 pinMode(s2,OUTPUT);
 pinMode(s3,OUTPUT);
void TCS()
 flag=0;
 digitalWrite(s1,HIGH);
 digitalWrite(s0,HIGH);
 digitalWrite(s2,LOW);
 digitalWrite(s3,LOW);
 attachInterrupt(0, ISR_INTO, CHANGE);
 timer0_init();
void ISR_INTO()
 counter++;
 void timer0_init(void)
  TCCR2A=0x00;
  TCCR2B=0x07;   //the clock frequency source 1024 points
  TCNT2= 100;    //10 ms overflow again
  TIMSK2 = 0x01; //allow interrupt
 int i=0;
 ISR(TIMER2_OVF_vect)//the timer 2, 10ms interrupt overflow again. Internal overflow interrupt executive function
    TCNT2=100;
    flag++;
 if(flag==1)
    countR=counter;
    Serial.print("red=");
    Serial.println(countR,DEC);
    digitalWrite(s2,HIGH);
    digitalWrite(s3,HIGH);
  else if(flag==2)
    countG=counter;
    Serial.print("green=");
    Serial.println(countG,DEC);
   else if(flag==3)
    countB=counter;
    Serial.print("blue=");
    Serial.println(countB,DEC);
    Serial.println("\n");
    else if(flag==4)
     flag=0;
       counter=0;
   TCS();
while(1);
That code makes it spit out alot of RGB(?) values to the serial monitor. But I want to use a button so that when I press it it does ONE color reading.
If possible I would also want to have some way to convert the values to display the color names, like: Red,Green,Blue,Pink... Are there any pre-made conversion tables for that sort of stuff?
