TCS3200 Sensor using as a trigger for a mini vibrating motor
I am already using the sensor to connect with an lcd:
Working with an arduino Uno and a normal TCS3200 sensor.
<#include <LiquidCrystal.h>
LiquidCrystal lcd(7, 6, 5, 4, 3, 2);//RS,EN,D4,D5,D6,D7
const int s0 = 8;
const int s1 = 9;
const int s2 = 10;
const int s3 = 11;
const int out = 12;
// LED pins connected to Arduino
int redLed = 16;
int greenLed = 15;
int blueLed = 14;
// Variables
int red = 0;
int green = 0;
int blue = 0;
lcd.begin(16, 2);
pinMode(s0, OUTPUT);
pinMode(s1, OUTPUT);
pinMode(s2, OUTPUT);
pinMode(s3, OUTPUT);
pinMode(out, INPUT);
pinMode(redLed, OUTPUT);
pinMode(greenLed, OUTPUT);
pinMode(blueLed, OUTPUT);
digitalWrite(s0, HIGH);
digitalWrite(s1, HIGH);
lcd.setCursor(0, 0);
lcd.print(" Color Detected ");//printing name
color();
Serial.print("R Intensity:");
Serial.print(red, DEC);
Serial.print(" G Intensity: ");
Serial.print(green, DEC);
Serial.print(" B Intensity : ");
Serial.print(blue, DEC);
//Serial.println();
if (red < blue && red < green && red < 20)
Serial.println(" - (Red Color)");
lcd.setCursor(0, 1);
lcd.print(" RED Color ");
digitalWrite(redLed, HIGH); // Turn RED LED ON
digitalWrite(greenLed, LOW);
digitalWrite(blueLed, LOW);
else if (blue < red && blue < green)
Serial.println(" - (Blue Color)");
lcd.print(" Blue Color ") ;
digitalWrite(redLed, LOW);
digitalWrite(blueLed, HIGH); // Turn BLUE LED ON
else if (green < red && green < blue)
Serial.println(" - (Green Color)");
lcd.print(" Green Color ");
digitalWrite(greenLed, HIGH); // Turn GREEN LED ON
else{
lcd.print(" Can't Identify");
delay (500);
void color()
digitalWrite(s2, LOW);
digitalWrite(s3, LOW);
//count OUT, pRed, RED
red = pulseIn(out, digitalRead(out) == HIGH ? LOW : HIGH);
digitalWrite(s3, HIGH);
//count OUT, pBLUE, BLUE
blue = pulseIn(out, digitalRead(out) == HIGH ? LOW : HIGH);
digitalWrite(s2, HIGH);
//count OUT, pGreen, GREEN
green = pulseIn(out, digitalRead(out) == HIGH ? LOW : HIGH);
now I want to connect a mini vibrating motor to the tcs3200 sensor. When the color is green these sensor should start vibrating ....
does anybody know how I need to do this? I'm a noob with arduino
kind regards Hermien
I think you just copied this sketch from web.
I indeed copied the code from the web... The problem is I want to connect the vibrating motor that you placed in the comment to the TCS3200 sensor. I want to let the sensor vibrate when the color is green can I do this with a simple if loop?
problem is you don't read :
ow okay sorry
The problem is already solved thx for the help
