Hello i would like to sense color of 3d printer filament.
and when i upload code i get error
Exception (0):
epc1=0x4000dce5 epc2=0x00000000 epc3=0x00000000 excvaddr=0x00000000 depc=0x00000000
my code is:
#include <Wire.h>
#include "Adafruit_TCS34725.h"
Adafruit_TCS34725 tcs = Adafruit_TCS34725(TCS34725_INTEGRATIONTIME_50MS, TCS34725_GAIN_4X); //Setup the colour sensor through Adafruit library
int R = 0;
int G = 0;
int B = 0;
int minR, minG, minB =255;
int maxR, maxG, maxB = 0;
int minThreshold = 10;
int calibState=0;
// if( CALIBRATON )
// calibState = 0;
// else
// minR = minG = minB = 0;
// maxR = maxG = maxB =255;
void DoButton()
if(calibState == 0)
minR = R;
minG = G;
minB = B;
calibState = 1;
else if(calibState == 1)
maxR = R;
maxG = G;
maxB = B;
calibState = 2;
uint16_t red, green, blue, clear;
delay(60);
tcs.getRawData(&red, &green, &blue, &clear);
uint16_t sum = clear;
float r, g, b;
r = red;
r /= sum;
g = green;
g /= sum;
b = blue;
b /= sum;
r *= 256;
g *= 256;
b *= 256;
R = r;
G = g;
B = b;
int R2 = map(R ,minR, maxR, 0, 255);
int G2 = map(G ,minG, maxG, 0, 255);
int B2 = map(B ,minB, maxB, 0, 255);
R = constrain(R2, 0 ,255);
G = constrain(G2, 0 ,255);
B = constrain(B2, 0 ,255);
int stateColor = -1;
if(R > B + minThreshold && R > G + minThreshold)
stateColor = 0;
else if(G > R + minThreshold && G > B + minThreshold)
stateColor = 1;
else if(B > R + minThreshold && B > G + minThreshold)
stateColor = 2;
int color = convertRGB24toRGB565(R,G,B);
Serial.print("RGB [");
Serial.print(R);
Serial.print(",");
Serial.print(G);
Serial.print(",");
Serial.print(B);
Serial.print("]");
Serial.print(" MIN [");
Serial.print(minR);
Serial.print(",");
Serial.print(minG);
Serial.print(",");
Serial.print(minB);
Serial.print("]");
Serial.print(" MAX [");
Serial.print(maxR);
Serial.print(",");
Serial.print(maxG);
Serial.print(",");
Serial.print(maxB);
Serial.print("]");
Serial.print(" Color:");
Serial.println(color);
uint16_t convertRGB24toRGB565(uint8_t r, uint8_t g, uint8_t b)
return ((r/8) << 11)|((g/4)<<5)|(b/8);
please help
