Log:
chbsp_board_init
Device 0: found
Initializing sensor(s)... chbsp_i2c_get_info
starting group... chbsp_group_pin_init
// 5 times starting here:
chbsp_reset_assert
chbsp_program_enable
chbsp_delay_ms: 1ms
chbsp_reset_release
chbsp_i2c_write this many bytes: 3 to adress: 0x45, data[0]: 0x85, data[1]: 0xFC, data[2]: 0xFF -> Succesfull
chbsp_i2c_write this many bytes: 3 to adress: 0x45, data[0]: 0x87, data[1]: 0x3, data[2]: 0x0 -> Succesfull
chbsp_i2c_write this many bytes: 2 to adress: 0x45, data[0]: 0xC4, data[1]: 0xB -> Succesfull
chbsp_i2c_write this many bytes: 4 to adress: 0x45, data[0]: 0x3, data[1]: 0x40, data[2]: 0xFC, data[3]: 0xFF -> Succesfull
chbsp_i2c_write this many bytes: 2 to adress: 0x45, data[0]: 0xC2, data[1]: 0x40 -> Succesfull
chbsp_i2c_write this many bytes: 2 to adress: 0x45, data[0]: 0xC2, data[1]: 0x11 -> Succesfull
chbsp_i2c_write this many bytes: 3 to adress: 0x45, data[0]: 0x85, data[1]: 0x20, data[2]: 0x1 -> Succesfull
chbsp_i2c_write this many bytes: 3 to adress: 0x45, data[0]: 0x86, data[1]: 0x80, data[2]: 0x5A -> Succesfull
chbsp_i2c_write this many bytes: 2 to adress: 0x45, data[0]: 0xC4, data[1]: 0x3 -> Succesfull
chbsp_program_disable
chbsp_i2c_write this many bytes: 1 to adress: 0x45, data[0]: 0x0 -> Succesfull
chbsp_i2c_read this many bytes: 2 from address: 0x45 | Response: received 2 bytes: data[0]: 0xA data[1]: 0x2
chbsp_i2c_write this many bytes: 3 to adress: 0x45, data[0]: 0x85, data[1]: 0x48, data[2]: 0x7 -> Succesfull
chbsp_i2c_write this many bytes: 3 to adress: 0x45, data[0]: 0x87, data[1]: 0xF, data[2]: 0x0 -> Succesfull
chbsp_i2c_write this many bytes: 16 to adress: 0x45, data[0]: 0x6, data[1]: 0x0, data[2]: 0x0, data[3]: 0x0, data[4]: 0x0, data[5]: 0xFA, data[6]: 0x0, data[7]: 0x0, data[8]: 0x64, data[9]: 0x0, data[10]: 0x0, data[11]: 0xC,
data[12]: 0x0, data[13]: 0x0, data[14]: 0x1, data[15]: 0x0 -> Succesfull
chbsp_i2c_write this many bytes: 3 to adress: 0x45, data[0]: 0x85, data[1]: 0x0, data[2]: 0xF8 -> Succesfull
chbsp_i2c_write this many bytes: 3 to adress: 0x45, data[0]: 0x87, data[1]: 0xFF, data[2]: 0x7 -> Succesfull
chbsp_i2c_write this many bytes: 2048 to adress: 0x45, data[0]: 0xA, data[1]: 0x12, data[2]: 0x9, data[3]: 0x12, data[4]: 0x8, data[5]: 0x12, data[6]: 0x7, data[7]: 0x12, data[8]: 0x6, data[9]: 0x12, data[10]: 0x5, data[11]:
0x12, data[12]: 0x4, data[13]: 0x12, data[14]: 0x31, data[15]: 0x80, data[16]: 0x10, data[17]: 0x0, data[18]: 0x81, data[19]: 0x4D, data[20]: 0x2, data[21]: 0x0, data[22]: 0xC2, data[23]: 0x43, data[24]: 0x3E, data[25]: 0x7,
data[26]: 0x6, data[27]: 0x43, data[28]: 0x4, data[29]: 0x43, data[30]: 0x81, data[31]: 0x43, data[32]: 0x8, data[33]: 0x0, data[34]: 0xA, data[35]: 0x43, data[36]: 0xC, data[37]: 0x93, data[38]: 0xB0, data[39]: 0x24, data[40]: 0x81, data[41]: 0x4C, data[42]: 0xA, data[43]: 0x0, data[44]: 0x7, data[45]: 0x43, data[46]: 0x8, data[47]: 0x47, data[48]: 0x35, data[49]: 0x40, data[50]: 0xDC, data[51]: 0x5, data[52]: 0xC, data[53]: 0x43, data[54]: 0x1F, data[55]: 0x41, data[56]: 0x2, data[57]: 0x0, data[58]: 0x4F, data[59]: 0x93, data[60]: 0x16, data[61]: 0x20, data[62]: 0x38, data[63]: 0x90, data[64]: 0x2C, data[65]: 0x0, data[66]: 0x1C, data[67]: 0x2C, data[68]: 0xF2, data[69]: 0x90, data[70]: 0x20, data[71]: 0x0, data[72]: 0x1, data[73]: 0x2, data[74]: 0x18, data[75]: 0x24, data[76]: 0xF, data[77]: 0x48, data[78]: 0xF, data[79]: 0x5C, data[80]: 0xF, data[81]: 0x5F, data[82]: 0x3E, data[83]: 0x40, data[84]: 0x1C, data[85]: 0x2, data[86]: 0xE, data[87]: 0x5F, data[88]: 0x2B, data[89]: 0x4E, data[90]: 0x3D, data[91]: 0x40, data[92]: 0xCC, data[93]: 0x6, data[94]: 0xD, data[95]: 0x5F, data[96]: 0xAE, data[97]: 0x8D, data[98]: 0x0, data[99]: 0x0, data[100]: 0x8D, data[101]: 0x4B -> Succesfull
chbsp_i2c_write this many bytes: 3 to adress: 0x45, data[0]: 0x85, data[1]: 0xC5, data[2]: 0x1 -> Succesfull
chbsp_i2c_write this many bytes: 3 to adress: 0x45, data[0]: 0x86, data[1]: 0x2D, data[2]: 0x2D -> Succesfull
chbsp_i2c_write this many bytes: 3 to adress: 0x45, data[0]: 0x85, data[1]: 0xA6, data[2]: 0x1 -> Succesfull
chbsp_i2c_write this many bytes: 3 to adress: 0x45, data[0]: 0x86, data[1]: 0x0, data[2]: 0x2 -> Succesfull
chbsp_delay_ms: 5ms
chbsp_i2c_write this many bytes: 3 to adress: 0x45, data[0]: 0x86, data[1]: 0x0, data[2]: 0x6 -> Succesfull
chbsp_delay_ms: 5ms
chbsp_i2c_write this many bytes: 3 to adress: 0x45, data[0]: 0x86, data[1]: 0x0, data[2]: 0x0 -> Succesfull
chbsp_i2c_write this many bytes: 2 to adress: 0x45, data[0]: 0xC2, data[1]: 0x2 -> Succesfull
chbsp_timestamp_ms
chbsp_i2c_mem_read this many bytes: 1 from adress: 0x2D, at mem adress: 0x14 transmission -> succesfull | Response: received 0 data: did not receive enough bytes.
chbsp_delay_ms: 10ms
chbsp_timestamp_ms
chbsp_timestamp_ms
chbsp_timestamp_ms
chbsp_timestamp_ms
chbsp_timestamp_ms
// Until here
FAILED: 1
// Extra I2C Scanner for checking reachable addresses
I2C scanner. Scanning ...
Found address: 41 (0x29)
Found 1 device(s).
Sensor Type Freq RTC Cal Firmware
0 CH101 0 Hz 0@100ms gpr_open_gpr-101_v40a
Configuring sensor(s)...
Setting config...
chbsp_i2c_mem_write this many bytes: 2 to adress: 0x2D, at mem adress: 0x01, data[0]: 0x1, data[1]: 0x2 -> received NACK on transmit of address.
chbsp_i2c_mem_read this many bytes: 2 from adress: 0x2D, at mem adress: 0x16 transmission -> succesfull | Response: received 0 data: did not receive enough bytes.
chbsp_i2c_mem_write this many bytes: 2 to adress: 0x2D, at mem adress: 0x07, data[0]: 0x1, data[1]: 0x0 -> received NACK on transmit of address.
Device 0: Error during ch_set_config()
Starting measurements
