TDS Meter cannot working with Ethernet
Hi guys, i want to build mini hydroponic system with IoT using Arduino Uno. I try to use TDS Meter module and Ethernet shield module together. If they are running separately, everything is fine, but when i put them together, the TDS Meter module keep showing 0ppm.
Can anybody help me?
#include <SPI.h>
#include <Ethernet.h>
// Enter a MAC address for your controller below.
// Newer Ethernet shields have a MAC address printed on a sticker on the shield
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
// if you don't want to use DNS (and reduce your sketch size)
// use the numeric IP instead of the name for the server:
//IPAddress server(74,125,232,128); // numeric IP for Google (no DNS)
char server[] = "base_url"; // name address for Google (using DNS)
// Set the static IP address to use if the DHCP fails to assign
IPAddress ip(192, 168, 0, 177);
IPAddress myDns(192, 168, 0, 1);
// Initialize the Ethernet client library
// with the IP address and port of the server
// that you want to connect to (port 80 is default for HTTP):
EthernetClient client;
//Constants
#define TdsSensorPin A2
#define VREF 5.0 // analog reference voltage(Volt) of the ADC
#define SCOUNT 30 // sum of sample point
int analogBuffer[SCOUNT]; // store the analog value in the array, read from ADC
int analogBufferTemp[SCOUNT];
int analogBufferIndex = 0,copyIndex = 0;
float averageVoltage = 0,tdsValue = 0,temperature = 25;
// Variables to measure the speed
unsigned long beginMicros, endMicros;
unsigned long byteCount = 0;
bool printWebData = true; // set to false for better speed measurement
pinMode(TdsSensorPin,INPUT);
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
// start the Ethernet connection:
Serial.println("Initialize Ethernet with DHCP:");
if (Ethernet.begin(mac) == 0) {
Serial.println("Failed to configure Ethernet using DHCP");
// Check for Ethernet hardware present
if (Ethernet.hardwareStatus() == EthernetNoHardware) {
Serial.println("Ethernet shield was not found. Sorry, can't run without hardware. :(");
while (true) {
delay(1); // do nothing, no point running without Ethernet hardware
if (Ethernet.linkStatus() == LinkOFF) {
Serial.println("Ethernet cable is not connected.");
// try to congifure using IP address instead of DHCP:
Ethernet.begin(mac, ip, myDns);
Serial.print(" DHCP assigned IP ");
Serial.println(Ethernet.localIP());
// give the Ethernet shield a second to initialize:
Serial.print("connecting to ");
Serial.print(server);
Serial.println("...");
// if you get a connection, report back via serial:
beginMicros = micros();
if (client.connect(server, 80)) {
tdsEc();
Serial.print("connected to ");
Serial.println(client.remoteIP());
// Make a HTTP request:
client.print("GET /hydrophonic/plant.php?wl=");
client.print(distance);
//client.print("&ph=");
//client.print(ph);
client.print("&tds=");
client.print(tdsValue);
//client.print("&ec=");
//client.print(ec);
client.print("&tmp=");
client.print(temp);
client.print("&hum=");
client.print(hum);
client.println(" HTTP/1.1");
client.println("Host: www.telebot.stg02.mobileforce.mobi");
client.println("Connection: close");
client.println();
// if you didn't get a connection to the server:
Serial.println("connection failed");
_delay(5000);
Serial.print("time spend ");
Serial.println(timeCounter);
void tdsEc(){
//Menghitung TDS/EC
static unsigned long analogSampleTimepoint = millis();
if(millis()-analogSampleTimepoint > 40U) //every 40 milliseconds,read the analog value from the ADC
analogBuffer[analogBufferIndex] = analogRead(TdsSensorPin); //read the analog value and store into the buffer
analogBufferIndex++;
if(analogBufferIndex == SCOUNT)
analogBufferIndex = 0;
static unsigned long printTimepoint = millis();
if(millis()-printTimepoint > 800U)
for(copyIndex=0;copyIndex<SCOUNT;copyIndex++)
analogBufferTemp[copyIndex]= analogBuffer[copyIndex];
averageVoltage = getMedianNum(analogBufferTemp,SCOUNT) * (float)VREF / 1024.0; // read the analog value more stable by the median filtering algorithm, and convert to voltage value
float compensationCoefficient=1.0+0.02*(temperature-25.0); //temperature compensation formula: fFinalResult(25^C) = fFinalResult(current)/(1.0+0.02*(fTP-25.0));
float compensationVolatge=averageVoltage/compensationCoefficient; //temperature compensation
tdsValue=(133.42compensationVolatgecompensationVolatgecompensationVolatge - 255.86compensationVolatgecompensationVolatge + 857.39compensationVolatge)*0.5; //convert voltage value to tds value
//Serial.print("voltage:");
//Serial.print(averageVoltage,2);
//Serial.print("V ");
Serial.print("TDS Value:");
Serial.print(tdsValue,0);
Serial.println("ppm");
int getMedianNum(int bArray[], int iFilterLen)
int bTab[iFilterLen];
for (byte i = 0; i<iFilterLen; i++)
bTab = bArray*;*
* int i, j, bTemp;*
* for (j = 0; j < iFilterLen - 1; j++)*
* for (i = 0; i < iFilterLen - j - 1; i++)*
_ if (bTab > bTab[i + 1])
bTemp = bTab;
bTab = bTab[i + 1];
bTab[i + 1] = bTemp;
if ((iFilterLen & 1) > 0)
bTemp = bTab[(iFilterLen - 1) / 2];
else*
* bTemp = (bTab[iFilterLen / 2] + bTab[iFilterLen / 2 - 1]) / 2;
return bTemp;
void _delay(float miliseconds)
timeCounter += miliseconds;
delay((int)miliseconds);
}*_
You can help yourself a lot by reading the following links instead of posting in the first section you came across which was COVID related !
Your topic was Moved to it's current location / section as it is more suitable.
Other DUPLICATE posts DELETED
Could you also take a few moments to Learn How To Use The Forum.
Other general help and troubleshooting advice can be found here.
