Hey all im very new to all this stuff and i need alittle advice i built a little monitor for water quality with a gravity tds meter v1 and used the sample code that come with it got it all working and printing fine but i was wondering if there is a way to print the PPM reading into EC reading by dividing the PPM reading by 500 and then having it print the calculated EC reading
Example if the tds meter is reading 700ppm and i divide that by 500 it equals 1.4 EC and then having that 1.4 ec print serial/lcd
I'm not sure if thats a thing but it would be handy thanks in advance
I'm currently on my phone atm but here is the sample code i am using to measure the PPM
DFRobot Gravity: Analog TDS Sensor/Meter
<https://www.dfrobot.com/wiki/index.php/Gravity:_Analog_TDS_Sensor_/_Meter_For_Arduino_SKU:_SEN0244>
This sample code shows how to read the tds value and calibrate it with the standard buffer solution.
707ppm(1413us/cm)@25^c standard buffer solution is recommended.
Created 2018-1-3
By Jason <jason.ling@dfrobot.com@dfrobot.com>
GNU Lesser General Public License.
See <http://www.gnu.org/licenses/> for details.
All above must be included in any redistribution.
/***********Notice and Trouble shooting***************
1. This code is tested on Arduino Uno with Arduino IDE 1.0.5 r2 and 1.8.2.
2. Calibration CMD:
enter -> enter the calibration mode
cal:tds value -> calibrate with the known tds value(25^c). e.g.cal:707
exit -> save the parameters and exit the calibration mode
#include <EEPROM.h>
#include "GravityTDS.h"
#define TdsSensorPin A1
GravityTDS gravityTds;
float temperature = 25,tdsValue = 0;
gravityTds.setPin(TdsSensorPin);
gravityTds.setAref(5.0); //reference voltage on ADC, default 5.0V on Arduino UNO
gravityTds.setAdcRange(1024); //1024 for 10bit ADC;4096 for 12bit ADC
gravityTds.begin(); //initialization
//temperature = readTemperature(); //add your temperature sensor and read it
gravityTds.setTemperature(temperature); // set the temperature and execute temperature compensation
gravityTds.update(); //sample and calculate
tdsValue = gravityTds.getTdsValue(); // then get the value
Serial.print(tdsValue,0);
Serial.println("ppm");
Serial.print("ppm ");
float EC = tdsValue/500;
Serial.print(EC,0);
Serial.println("EC");
My writing isn't the best im dyslexic and had to get a job at a young age to support myself so i didn't finish my schooling but thanks for pointing it out
No worries I'm happy you asked a question and received help. Don't ever feel bad about asking a question. IMHO the only bad question is the one you didn't ask.
