Tea-o-matic
Afternoon all!
I apologise if the name is slightly deceptive, this isn't a robot that will physically make the tea. But it is a robot that will get tea made (if that makes any sense). The first project I made with my GLCD (192x64) was one that I had been promising my mother I would do for ages, a robot that will get tea made for her. As I have few motors and materials for a robotic arm (Mum is also afraid of me using any voltage above about 50, don't tell her about the stripped out plasma ball) I decided that the best way to get teas made would be to make a device to order the tea to be made! So here it is: The Tea-o-matic
And here is the code I hope it is well enough commented, if you have a smaller GLCD then you may need to alter the messages and the title placement (0,3) should do.
#include <Arial14.h>             //Title font
#include <ks0108.h>              //GLCD Library
#include <step11.h>              //Hello Bitmap
#include <SystemFont5x7.h>       //Fixed width font
int turn = random(1,5);          //Whos turn it is (random)
int pinBtn = 2;                  //The pin the button is on
int wasOnLastLoop;               //Weather the button was
                                 //  pressed on the last
                                 //  loop
int ledPin = 13;                 //LED for visualization of
                                 //  sound (use 13 for
                                 //  built-in led)
int backPin = 12;                //Pin the the backlight is
                                 //  connected to (for
                                 //  notification that some
                                 //  -one has been selected
int speakerPin = 3;              //speaker connected to one
                                 //  of the PWM ports
//frequencies for the tones we can to use
//used http://home.mit.bme.hu/~bako/tonecalc/tonecalc.htm to
//  get more of these
#define c 261    //C
#define d 294    //D
#define e 329    //E
#define f 349    //F
#define g 391    //G
#define gS 415   //G Sharp
#define a 440    //A
#define aS 455   //A Sharp
#define b 466    //B
#define cH 523   //C High
#define cSH 554  //C High Sharp
#define dH 587   //D High
#define dSH 622  //D High Sharp
#define eH 659   //E High
#define fH 698   //F High
#define fSH 740  //F High Sharp
#define gH 784   //G High
#define gSH 830  //G High Sharp
#define aH 880   //A High
void beep (unsigned char speakerPin, int frequencyInHertz, long timeInMilliseconds)
    digitalWrite(ledPin, HIGH);
    //use led to visualize the notes being played
    int x;
    long delayAmount = (long)(1000000/frequencyInHertz);
    long loopTime = (long)((timeInMilliseconds*1000)/(delayAmount*2));
    for (x=0;x<loopTime;x++)
        digitalWrite(speakerPin,HIGH);
        delayMicroseconds(delayAmount);
        digitalWrite(speakerPin,LOW);
    digitalWrite(ledPin, LOW);
    //set led back to low
    delay(20);
    //a little delay to make all notes sound separate
void setup(){
  //Pin Setup
  pinMode(pinBtn, INPUT);         //Sets the Button to an input
  pinMode(ledPin, OUTPUT);        //Sets the ledPin to be an output
  pinMode(speakerPin, OUTPUT);         //Sets the speakerPin to be an output
  pinMode(backPin, OUTPUT);       //Sets the Backlight Pin to be an output
  digitalWrite(backPin, HIGH);  //Switches the LCD Backlight on.
  //GLCD Setup
  GLCD.Init(NON_INVERTED);
  GLCD.ClearScreen();
  GLCD.SelectFont(System5x7);
  //GLCD Test
  GLCD.DrawBitmap(step11, 32,0,WHITE);
  for(int i = 0; i < 192; i++){
   GLCD.DrawVertLine(i, 0, 64, BLACK);
   delay(2);
   GLCD.DrawVertLine(i, 0, 64, WHITE);
   delay(2);
  //march();
  whosTurn();
void loop(){
 //Go through this all the while the user holds the button down
 while(digitalRead(pinBtn) == 1){
   GLCD.ClearScreen();    //Remove the last frame
   wasOnLastLoop=1;       //Make sure the program knows that this was ran
                          //  on the last loop execution
   whosTurn();            //Display who's turn it is to make tea and
                          //  redraw the title (GLCD.ClearScreen()
                          //  erased it.)
   turn = random(1, 5);   //Chose a person (int 1-4 incl.) to make tea
                          //  next
   delay(100);            //Allow the user time to see what is in the
                          //  frame
  if(wasOnLastLoop==1)
   //Play a noise so everyone knows someone has to make the tea
   tone(speakerPin, aH, 300);   //Play note A High
   delay(300);                  //Wait for note to finish
   tone(speakerPin, a, 300);    //Play note A
   delay(300);                  //Waait for note to finish
   //Flash backlight
   flashBackLight();
   //===================== Prevent cheating ===================
   for(int i = 0; i < 6000; i++){             //Loop 6000 times
     if(digitalRead(pinBtn) == 1){            //Is someone tring
                                              //  to go again?
       tone(speakerPin, c, 500);              //Make a noise
       //Turn the backlight back on
       //Write out why it didn't select another person
       GLCD.CursorTo(0,5);
       GLCD.Puts("You must wait ten minutes before");
       GLCD.CursorTo(0,6);
       GLCD.Puts("   I can provide with the next");
       GLCD.CursorTo(0,7);
       GLCD.Puts("   persons name!");
       //Flash backlight
       flashBackLight();
     //Make the loop take some time, 6000x100 = 10 mins
     delay(100);
   //Ok, we have done this now, don't need to prevent cheating next
   //  time around, wait till the user releases the button next
   //  before running this code again
   wasOnLastLoop = 0;
  Serial.println(digitalRead(pinBtn));    //For debugging
void flashBackLight(){
   //Make the screen flash (assuming the backlight is on backPin
   digitalWrite(backPin, HIGH);    //On
   delay(200);                     //Wait
   digitalWrite(backPin,LOW);      //Off
   delay(200);                     //Wait
   delay(200);                     //Wait
   delay(200);                     //Wait
   delay(200);                     //Wait
   delay(200);                     //Wait
void whosTurn(){
  GLCD.SelectFont(Arial_14);             //Title font
  GLCD.CursorTo(5,0);                    //Centre screen
  GLCD.Puts("Tea-o-matic!");             //Title itself
  GLCD.DrawHoriLine(0, 12, 192, BLACK);  //Underline the title
  GLCD.SelectFont(System5x7);            //Main font
  GLCD.CursorTo(0,2);                    //Body location
  switch(turn){
  case 1:    //Turn = 1
    //Simon's turn
    GLCD.Puts("Simon's Turn");//Write to screen
  case 2:    //Turn = 2
    //Laura's turn
    GLCD.Puts("Laura has to make it");//Write to screen
  case 3:    //Turn = 3
    //Mum's turn
    GLCD.Puts("Mum must put the kettle on");//Write to screen
  case 4:    //Turn = 4
    //Dad's turn
    GLCD.Puts("Now Dad has to make the tea!!");//Write to screen
Classic invention!
Nice! Though could you please shrink the picture a little bit, it took a fair bit of scrolling to see the whole thing! :slight_smile:
