Teachable Robotic Arm feedback seros
Hello,
I am in the processing of building a robotic arm using an arduino uno, laser cut pieces and six analog servos from adafruit. Here is what the robot looks like so far http://i.imgur.com/1HFAxsXh.jpg
I am using the record/playback code to record the movements of the base servo and then play it back. What I am trying to do is change the code given and incorporate all six servos so when I hit record it records the movements of all six servos and when I hit replay it replays all the movements of each servo.
Here is a link to the code that Adafruit provided. GitHub - adafruit/Feedback-Servo-Record-and-Play: Example Arduino sketch for recording, then playing back servo activity. Requires a "feedback" servo
Which works for just one servo.
What I am trying to do is use the servos as inputs and record their motions when the record button is pressed. Then I want to save those values to eeprom and when the play button is pressed incrementally give back those servo values as commands to each servo. Here Is my code that I have I was wondering if anyone could let me know what I am doing wrong.
//Robotic Arm
#include <Servo.h>
#include <EEPROM.h>
#define CALIB_MAX 512
#define CALIB_MIN 100
#define SAMPLE_DELAY 25 // in ms, 50ms seems good
uint8_t recordButtonPin = 6;
uint8_t playButtonPin = 7;
uint8_t servo1Pin = 8;
uint8_t servo2Pin = 9;
uint8_t servo3Pin = 10;
uint8_t servo4Pin = 11;
uint8_t servo5Pin = 12;
uint8_t servo6Pin = 13;
uint8_t servo1FeedbackPin = A0;
uint8_t servo2FeedbackPin = A1;
uint8_t servo3FeedbackPin = A2;
uint8_t servo4FeedbackPin = A3;
uint8_t servo5FeedbackPin = A4;
uint8_t servo6FeedbackPin = A5;
uint8_t ledPin = 3;
Servo servo1;
Servo servo2;
Servo servo3;
Servo servo4;
Servo servo5;
Servo servo6;
  pinMode(recordButtonPin, INPUT);
  digitalWrite(recordButtonPin, HIGH);
  pinMode(playButtonPin, INPUT);
  digitalWrite(playButtonPin, HIGH);
  pinMode(ledPin, OUTPUT);
  Serial.println("Servo RecordPlay");
 if (! digitalRead(recordButtonPin)) {
   delay(10);
   // wait for released
   while (! digitalRead(recordButtonPin));
   delay(20);
   // OK released!
   recordAllServos(servo1Pin, servo1FeedbackPin, recordButtonPin);
  if (! digitalRead(playButtonPin)) {
   delay(10);
   while (! digitalRead(playButtonPin));
   delay(20);
   // OK released!
   playAllServo(servo1Pin, playButtonPin);
void playAllServo(uint8_t servo1Pin, uint8_t buttonPin) {
  Serial.println("Playing");
  servo1.attach(servo1Pin);
  servo2.attach(servo2Pin);
  servo3.attach(servo3Pin);
  servo4.attach(servo4Pin);
  servo5.attach(servo5Pin);
  servo5.attach(servo6Pin);
  while (digitalRead(buttonPin)) {
  uint8_t x = EEPROM.read(addr);
  Serial.print("Read EE Servo 1: "); Serial.print(x);
    if (x == 255) break;
    // map to 0-180 degrees
    x = map(x1, 0, 254, 0, 180);
    Serial.print(" -> "); Serial.println(x);
    servo1.write(x);
    addr+++;
  Serial.print("Read EE Servo 2: "); Serial.print(x);
    x = map(x, 0, 254, 0, 180);
  servo2.write(x);
    addr+++;
  Serial.print("Read EE Servo 3: "); Serial.print(x);
  servo3.write(x);
    addr+++;
  Serial.print("Read EE Servo 4: "); Serial.print(x);
  servo4.write(x);
    addr+++;
  Serial.print("Read EE Servo 5: "); Serial.print(x);
  servo5.write(x);
    addr+++;
  Serial.print("Read EE Servo 6: "); Serial.print(x);
  servo6.write(x);
    addr+++;
  Serial.println("Done");
  servo1.detach();
  delay(250);
void recordAllServos(uint8_t servo1Pin, uint8_t servo1FeedbackPin, uint8_t buttonPin) {
  uint16_t addr = 0;
  Serial.println("Recording");
  digitalWrite(ledPin, HIGH);
  pinMode(servo1FeedbackPin, INPUT);
  pinMode(servo2FeedbackPin, INPUT);
  pinMode(servo3FeedbackPin, INPUT);
  pinMode(servo4FeedbackPin, INPUT);
  pinMode(servo5FeedbackPin, INPUT);
  pinMode(servo6FeedbackPin, INPUT);
     readAllServo(servo1FeedbackPin);
     readAllServo(servo2FeedbackPin);
     readAllServo(servo3FeedbackPin);
     readAllServo(servo4FeedbackPin);
     readAllServo(servo5FeedbackPin);
     readAllServo(servo6FeedbackPin);
    if (addr == 1024) break;
    delay(SAMPLE_DELAY);
  if (addr != 1024) EEPROM.write(addr, 255);
  digitalWrite(ledPin, LOW);
  delay(250);
void readAllServo(uint8_t servo1FeedbackPin)
     uint16_t a = analogRead(servo1FeedbackPin);
     Serial.print("Read analog pin "); Serial.print(servo1FeedbackPin); Serial.print(": "); Serial.print(a);
     if (a < CALIB_MIN) a = CALIB_MIN;
     if (a > CALIB_MAX) a = CALIB_MAX;
     a = map(a, CALIB_MIN, CALIB_MAX, 0, 254);
     Serial.print(" -> "); Serial.println(a);
     EEPROM.write(addr, a); //save servo 1 values to eeprom
     addr++
It sounds like an array of servos would be a good way to go.
Firstly abandon the separate variables for each servo, use an array for the servo
control pin numbers, an array for the analog feedback pin numbers.
Then any use of the one servo code pins gets replaced by a loop over the
relevant array (either sampling or playing back).
Your EEPROM will last 1/6 as long of course which may be an issue given
there's only 1k.
