First, apologies because I can't find the "search" function for the forum. The top-of-page search gives me Google.
Any tricks or techniques for connecting/connectors on standard 0.1 header pins? I'm using multiple OctoBrites (from Macetech) that can have the 4 "center" pins paralleled, but I need pin0 of Octobrite0 to go to pin5 of Octobrite1, etc. I can of course find a plethora of 6, 4, and 2 position sockets, but how do you like to deal with single-wire connections to/from header pins, assuming I don't want to hard-wire the connections (still prototyping)? If you can't tell-- I'm a newbie!
Thanks, Richard. Pilot error on the search function, then (sheepish me).
I'm moving past the breadboard stage, but not building a "final" version of the project. Your suggestion is pretty much what I've come up with so far: just use one side of a 2-position connector. That might be the easiest in the long run.
Appreciate the reply,
Jeff
