Teensy 3.1 Breakout board to access all pins
Im using a Breakout board for the teensy 3.1.
Im trying to pulse a pin for 2000ms delay. It works with the standard pins but not if i try to access all the other pins? :o
Ive checked continuity and its okay?
Is Another boot loader or something required to now program the extra Pins :confused:
Kind regards Baggey
Is that a question or a statement? Why don't you know what punctuation to use for a statement, if that is a statement? Why does it sound like a statement when it ends with a question mark.
What pins does "it not work for" and how have you tried to pulse those pins?
What model Teensy 3.1 breakout are you using? Did you solder all the bottom pins successfully?
I don't think so.I've got a Teensy 3.2 which is the same pinout. I'm using the underside pins to read from a paper tape reader unit and they work fine. I've also used the bottom pins on a 3 section 7 segment display and all worked fine.
Where's your code?
