Teensy 3.1 I2C communication (Where are SDA & SCL)
On the Teensy 3.1, where are the I2C pins (SDA, SCL) located?
I ~thought~ it was pin 18 & 19.
I loaded the code below. I have (2) 4.7k resistors on the I2C inputs on my MCP23008.
When I put my scope on SDA or SCL, there is no transmission, just 3.3V steady.
#include <Wire.h>
   Wire.begin();                      // initialise the wire library and hardware
   Wire.beginTransmission(0x40);      // start talking to the device
   Wire.send(0x00);                   // select the IODIR register
   Wire.send(0xff);                   // set register value-all high, sets all pins as outputs on MCP23008
   Wire.endTransmission();            // stop talking to the devicevice
   pinMode(13, OUTPUT);
   Wire.send(0x09);                   // select the GPIO register
   digitalWrite(13, LOW);
   delay(500);                        // wait for 1/2 a second
   Wire.send(0x00);                   // set register value-all low
   digitalWrite(13, HIGH);
Hi and welcome.
May i ask why you ask this question on the Arduino forum, and not on the teensy forum (click !).
I googled a bit, and found no references to teensy 3.1 and I2C, except for people having trouble with it.
So no instructions on how to do it.
Try using address 0x20 instead of 0x40. When specifying the I2C address to the Arduino/Teensy wire library, you must omit the R/W bit.
Pete
P.S. and, as MAS3 says, you'd be better off asking about a Teensy in the Teensy forums.
