Hello everyone!
I am not great at the whole C++ Coding aspect. I am keen to learn too! However. I am wading my way through how to tap into the display module on my Volvo C30. So I can overlay the image data on a Raspberry Pi to make my own audio/ Climate control interface for my car.
I see that someone has already semi-done this.
link.
Straight away, I know that this is for a much older version and I am trying to run it on. But I see that other people have nearly sussed this out too.
I have been on this all day and I simply cannot get it to compile.
This is what I've got.
#include "referenceBmp.h"
#ifdef PRINT_DEBUG
#endif
#define PinInt 12
#define data0 2
#define data1 14
#define data2 7
#define data3 8
#define data4 6
#define data5 20
#define data6 21
#define data7 5
void setup(){
pinMode(ClkPin, INPUT); // sets the digital pin as input : CLK
pinMode(data0, INPUT); // sets the digital pin as input : D0
pinMode(data1, INPUT); // sets the digital pin as input : D1
pinMode(data2, INPUT); // sets the digital pin as input : D2
pinMode(data3, INPUT); // sets the digital pin as input : D3
pinMode(data4, INPUT); // sets the digital pin as input : D4
pinMode(data5, INPUT); // sets the digital pin as input : D5
pinMode(data6, INPUT); // sets the digital pin as input : D6
pinMode(data7, INPUT); // sets the digital pin as input : D7
attachInterrupt(ClkPin, isrService, FALLING); // data ready
NVIC_SET_PRIORITY(IRQ_GPIO6789, 0);
//wait opening com port on pc side
while(!Serial);
Serial.println(__DATE__);
Serial.println(__TIME__);
Serial.print("Arduino Ide Version ");
Serial.print(ARDUINO, DEC);
Serial.println("");
Serial.print("Teensyduino Version ");
Serial.print(TEENSYDUINO, DEC);
Serial.println("");
Serial.print("Cpu frequency ");
Serial.print(F_CPU, DEC);
Serial.println("");
#define DATABUFFER_SIZE_2048 (2048)
#define DATABUFFER_SIZE_2096 (2096)
#define DATABUFFER_SIZE DATABUFFER_SIZE_2048
extern volatile unsigned char newDataIsr[DATABUFFER_SIZE];
extern volatile unsigned char dataReadyIsr;
extern const unsigned char protocolFound;
#ifdef PRINT_DEBUG
extern volatile unsigned int startFound;
#endif
#define NB_COLUMNS_32 32
#define NB_ROWS_64 64
#define PIXEL_DATA_SIZE_2048 (NB_ROWS_64*NB_COLUMNS_32)
unsigned char bmpData[PIXEL_DATA_SIZE_2048];
#define COLUMN_SIZE_8 8
char bmpDataReady = 0;
void bmpDataBuild(void)
unsigned int i = 0;
unsigned int j = 0;
unsigned int k = 0;
unsigned int pixelStart = 0;
unsigned int pixelXOffset = 0;
unsigned int pixelYOffset = 0;
unsigned char tmp = 0;
bmpDataReady = 0;
for(i = 0; i < PIXEL_DATA_SIZE_2048; i++)
bmpData[i] = 0;
//remove 3 bytes every 128 bytes
if(protocolFound)
for(i = 0; i < DATABUFFER_SIZE_2096; i++)
if(!(i%128))
for(j = 0; j < (DATABUFFER_SIZE_2096 - i); j++)
newDataIsr[i+j] = newDataIsr[i+j+3];
//start at bottom end
pixelStart += (PIXEL_DATA_SIZE_2048 - (NB_COLUMNS_32 * COLUMN_SIZE_8));
for(j = 0; j < COLUMN_SIZE_8; j++)
cli();
bmpData[i] |= (((newDataIsr[pixelStart + pixelXOffset] & (0x80 >> pixelYOffset)) >> ((COLUMN_SIZE_8 - 1) - pixelYOffset)) << ((COLUMN_SIZE_8 - 1) - j));
sei();
pixelXOffset++;
if(pixelXOffset >= (NB_COLUMNS_32 * COLUMN_SIZE_8))
pixelXOffset = 0;
pixelYOffset++;
if(pixelYOffset >= COLUMN_SIZE_8)
pixelYOffset = 0;
pixelStart -=(NB_COLUMNS_32 * COLUMN_SIZE_8);
if(protocolFound)
#if 1
//1st pass
j = ((32*32)+16);
for(k = 0; k < 32; k++)
for(i = (32*k); i < (32*k)+16; i++)
tmp = bmpData[i+j];
bmpData[i+j] = bmpData[i];
bmpData[i] = tmp;
#endif
#if 1
//2nd pass
j = 32*32;
for(k = 0; k < 8; k++)
for(i = (32*k); i < (32*k)+32; i++)
tmp = bmpData[i+j];
bmpData[i+j] = bmpData[i+(32*8)];
bmpData[i+(32*8)] = tmp;
#endif
#if 1
//3rd pass
j = 32*32;
tmp = bmpData[i+j];
bmpData[i+j] = bmpData[i+(32*16)];
bmpData[i+(32*16)] = tmp;
#endif
#if 1
//4th pass
j = 32*40;
tmp = bmpData[i+j];
bmpData[i+j] = bmpData[i+(32*24)];
bmpData[i+(32*24)] = tmp;
#endif
#if 1
//5th pass
j = 32*48;
tmp = bmpData[i+j];
bmpData[i+j] = bmpData[i+(32*40)];
bmpData[i+(32*40)] = tmp;
#endif
bmpDataReady = 1;
//1Bit 256*64 BMP file header
#define BMP_HEADER_SIZE_62 62
const unsigned char bmpHeader[BMP_HEADER_SIZE_62]={
0x42,0x4D,0x3E,0x08,0x00,0x00,0x00,0x00,0x00,0x00,0x3E,0x00,0x00,0x00,0x28,0x00,
0x00,0x00,0x00,0x01,0x00,0x00,0x40,0x00,0x00,0x00,0x01,0x00,0x01,0x00,0x00,0x00,
0x00,0x00,0x00,0x08,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0xFF,0xFF,0x00
#define BMP_FILE_SIZE_2110 (BMP_HEADER_SIZE_62 + PIXEL_DATA_SIZE_2048)
unsigned char bmpFile[BMP_FILE_SIZE_2110];
char bmpFileReady = 0;
void bmpFileBuild(void)
unsigned int i = 0;
bmpFileReady = 0;
if(bmpDataReady)
//1 - Header first
for(i = 0; i < BMP_HEADER_SIZE_62; i++)
bmpFile[i] = bmpHeader[i];
//2 - Then pixel data, bottom to top aligned
for(i = BMP_HEADER_SIZE_62; i < BMP_FILE_SIZE_2110; i++)
bmpFile[i] = bmpData[i-BMP_HEADER_SIZE_62];
bmpFileReady = 1;
// int incomingByte = 0; // for incoming serial data
unsigned int i = 0;
#ifdef PRINT_DEBUG
unsigned char minRef = 100;
unsigned char maxRef = 0;
unsigned char currentRef = 0;
unsigned int errors = 0;
unsigned int nbNoError = 0;
#endif
while(1)
// if (Serial.available() > 0)
// // read the incoming byte:
// incomingByte = Serial.read();
// if(incomingByte == 'b')
// bmpDataReady = 0;
// bmpFileReady = 0;
// dataReadyIsr = 0;
delay(100);
if(bmpFileReady == 0)
if(dataReadyIsr)
bmpDataBuild();
bmpFileBuild();
if(bmpFileReady == 1)
bmpFileReady = 2;
while(!Serial);
#ifndef PRINT_DEBUG
for(i = 0; i < BMP_FILE_SIZE_2110; i++)
//print extra zero if less than two chars
if(bmpFile[i] < 0x10) Serial.print("0");
Serial.print(bmpFile[i], HEX);
//compare with a reference file
//if(bmpFile[i] != referenceBmp[i]) errors++;
Serial.println("");
#endif
#ifdef PRINT_DEBUG
/* for(i = 0; i < 2048; i++)
if(newDataIsr[i] < 0x10) Serial.print("0");
Serial.print(newDataIsr[i], HEX);
Serial.println("");
//stats about errors between current file and reference file
currentRef = 100 - ((errors * 100) / BMP_FILE_SIZE_2110);
if(currentRef < minRef) minRef = currentRef;
if(currentRef > maxRef) maxRef = currentRef;
if(currentRef == 100) nbNoError++;
Serial.println("MIN<CUR<MAX NBNOERR NBSTART");
Serial.print(minRef, DEC);
Serial.print(" ");
Serial.print(currentRef, DEC);
Serial.print(" ");
Serial.print(maxRef, DEC);
Serial.print(" ");
Serial.print(nbNoError, DEC);
Serial.print(" ");
Serial.println("NBSTART startFound");
Serial.print(startFound, DEC);
Serial.print(" ");
Serial.println("");
errors = 0;
#endif
bmpDataReady = 0;
bmpFileReady = 0;
dataReadyIsr = 0;
// watermark generates this interrupt
FASTRUN inline void isrService()
But when I try to compile it, I get a whole host of errors...
C:\Users\james\AppData\Local\Temp\.arduinoIDE-unsaved2023113-15740-1eayfqr.42v4\sketch_dec3a\sketch_dec3a.ino: In function 'void setup()':
C:\Users\james\AppData\Local\Temp\.arduinoIDE-unsaved2023113-15740-1eayfqr.42v4\sketch_dec3a\sketch_dec3a.ino:24:9: error: 'ClkPin' was not declared in this scope
24 | pinMode(ClkPin, INPUT); // sets the digital pin as input : CLK
C:\Users\james\AppData\Local\Temp\.arduinoIDE-unsaved2023113-15740-1eayfqr.42v4\sketch_dec3a\extra_code.ino: At global scope:
C:\Users\james\AppData\Local\Temp\.arduinoIDE-unsaved2023113-15740-1eayfqr.42v4\sketch_dec3a\extra_code.ino:192:6: error: redefinition of 'void attachInterruptVector(IRQ_NUMBER_t, void (*)())'
192 | void attachInterruptVector(enum IRQ_NUMBER_t irq, void (*function)(void))
In file included from C:\Users\james\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\cores\teensy4/core_pins.h:32,
from C:\Users\james\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\cores\teensy4/wiring.h:39,
from C:\Users\james\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\cores\teensy4/WProgram.h:46,
from C:\Users\james\AppData\Local\Temp\arduino\sketches\E50839B664744489CFBE0D0A7C467024\pch\Arduino.h:6:
C:\Users\james\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\cores\teensy4/imxrt.h:436:20: note: 'void attachInterruptVector(IRQ_NUMBER_t, void (*)())' previously defined here
436 | static inline void attachInterruptVector(IRQ_NUMBER_t irq, void (*function)(void)) { _VectorsRam[irq + 16] = function; asm volatile("": : :"memory"); }
C:\Users\james\AppData\Local\Temp\.arduinoIDE-unsaved2023113-15740-1eayfqr.42v4\sketch_dec3a\extra_code.ino: In function 'void attachInterrupt(uint8_t, void (*)(), int)':
C:\Users\james\AppData\Local\Temp\.arduinoIDE-unsaved2023113-15740-1eayfqr.42v4\sketch_dec3a\extra_code.ino:200:18: warning: unused variable 'cfg' [-Wunused-variable]
200 | uint32_t cfg, mask;
C:\Users\james\AppData\Local\Temp\.arduinoIDE-unsaved2023113-15740-1eayfqr.42v4\sketch_dec3a\extra_code.ino: In function 'void _init_Teensyduino_internal_()':
C:\Users\james\AppData\Local\Temp\.arduinoIDE-unsaved2023113-15740-1eayfqr.42v4\sketch_dec3a\extra_code.ino:605:9: error: 'FTM0_CNT' was not declared in this scope
605 | FTM0_CNT = 0;
C:\Users\james\AppData\Local\Temp\.arduinoIDE-unsaved2023113-15740-1eayfqr.42v4\sketch_dec3a\extra_code.ino:606:9: error: 'FTM0_MOD' was not declared in this scope
606 | FTM0_MOD = DEFAULT_FTM_MOD;
C:\Users\james\AppData\Local\Temp\.arduinoIDE-unsaved2023113-15740-1eayfqr.42v4\sketch_dec3a\extra_code.ino:606:20: error: 'DEFAULT_FTM_MOD' was not declared in this scope
C:\Users\james\AppData\Local\Temp\.arduinoIDE-unsaved2023113-15740-1eayfqr.42v4\sketch_dec3a\extra_code.ino:607:9: error: 'FTM0_C0SC' was not declared in this scope
607 | FTM0_C0SC = 0x28; // MSnB:MSnA = 10, ELSnB:ELSnA = 10
C:\Users\james\AppData\Local\Temp\.arduinoIDE-unsaved2023113-15740-1eayfqr.42v4\sketch_dec3a\extra_code.ino:608:9: error: 'FTM0_C1SC' was not declared in this scope
608 | FTM0_C1SC = 0x28;
C:\Users\james\AppData\Local\Temp\.arduinoIDE-unsaved2023113-15740-1eayfqr.42v4\sketch_dec3a\extra_code.ino:609:9: error: 'FTM0_C2SC' was not declared in this scope
609 | FTM0_C2SC = 0x28;
C:\Users\james\AppData\Local\Temp\.arduinoIDE-unsaved2023113-15740-1eayfqr.42v4\sketch_dec3a\extra_code.ino:610:9: error: 'FTM0_C3SC' was not declared in this scope
610 | FTM0_C3SC = 0x28;
C:\Users\james\AppData\Local\Temp\.arduinoIDE-unsaved2023113-15740-1eayfqr.42v4\sketch_dec3a\extra_code.ino:611:9: error: 'FTM0_C4SC' was not declared in this scope
611 | FTM0_C4SC = 0x28;
C:\Users\james\AppData\Local\Temp\.arduinoIDE-unsaved2023113-15740-1eayfqr.42v4\sketch_dec3a\extra_code.ino:612:9: error: 'FTM0_C5SC' was not declared in this scope
612 | FTM0_C5SC = 0x28;
C:\Users\james\AppData\Local\Temp\.arduinoIDE-unsaved2023113-15740-1eayfqr.42v4\sketch_dec3a\extra_code.ino:627:9: error: 'FTM0_SC' was not declared in this scope
627 | FTM0_SC = FTM_SC_CLKS(1) | FTM_SC_PS(DEFAULT_FTM_PRESCALE);
C:\Users\james\AppData\Local\Temp\.arduinoIDE-unsaved2023113-15740-1eayfqr.42v4\sketch_dec3a\extra_code.ino:627:19: error: 'FTM_SC_CLKS' was not declared in this scope
C:\Users\james\AppData\Local\Temp\.arduinoIDE-unsaved2023113-15740-1eayfqr.42v4\sketch_dec3a\extra_code.ino:627:46: error: 'DEFAULT_FTM_PRESCALE' was not declared in this scope
C:\Users\james\AppData\Local\Temp\.arduinoIDE-unsaved2023113-15740-1eayfqr.42v4\sketch_dec3a\extra_code.ino:627:36: error: 'FTM_SC_PS' was not declared in this scope
C:\Users\james\AppData\Local\Temp\.arduinoIDE-unsaved2023113-15740-1eayfqr.42v4\sketch_dec3a\extra_code.ino:628:9: error: 'FTM1_CNT' was not declared in this scope
628 | FTM1_CNT = 0;
C:\Users\james\AppData\Local\Temp\.arduinoIDE-unsaved2023113-15740-1eayfqr.42v4\sketch_dec3a\extra_code.ino:629:9: error: 'FTM1_MOD' was not declared in this scope
629 | FTM1_MOD = DEFAULT_FTM_MOD;
C:\Users\james\AppData\Local\Temp\.arduinoIDE-unsaved2023113-15740-1eayfqr.42v4\sketch_dec3a\extra_code.ino:630:9: error: 'FTM1_C0SC' was not declared in this scope
630 | FTM1_C0SC = 0x28;
C:\Users\james\AppData\Local\Temp\.arduinoIDE-unsaved2023113-15740-1eayfqr.42v4\sketch_dec3a\extra_code.ino:631:9: error: 'FTM1_C1SC' was not declared in this scope
631 | FTM1_C1SC = 0x28;
C:\Users\james\AppData\Local\Temp\.arduinoIDE-unsaved2023113-15740-1eayfqr.42v4\sketch_dec3a\extra_code.ino:632:9: error: 'FTM1_SC' was not declared in this scope
632 | FTM1_SC = FTM_SC_CLKS(1) | FTM_SC_PS(DEFAULT_FTM_PRESCALE);
C:\Users\james\AppData\Local\Temp\.arduinoIDE-unsaved2023113-15740-1eayfqr.42v4\sketch_dec3a\extra_code.ino: In function 'void analogWrite(uint8_t, int)':
C:\Users\james\AppData\Local\Temp\.arduinoIDE-unsaved2023113-15740-1eayfqr.42v4\sketch_dec3a\extra_code.ino:807:24: warning: comparison of integer expressions of different signedness: 'int' and 'uint32_t' {aka 'long unsigned int'} [-Wsign-compare]
807 | } else if (val >= max) {
C:\Users\james\AppData\Local\Temp\.arduinoIDE-unsaved2023113-15740-1eayfqr.42v4\sketch_dec3a\extra_code.ino:820:20: error: 'FTM1_CH0_PIN' was not declared in this scope
820 | if (pin == FTM1_CH0_PIN || pin == FTM1_CH1_PIN) {
C:\Users\james\AppData\Local\Temp\.arduinoIDE-unsaved2023113-15740-1eayfqr.42v4\sketch_dec3a\extra_code.ino:820:43: error: 'FTM1_CH1_PIN' was not declared in this scope
C:\Users\james\AppData\Local\Temp\.arduinoIDE-unsaved2023113-15740-1eayfqr.42v4\sketch_dec3a\extra_code.ino:821:52: error: 'FTM1_MOD' was not declared in this scope
821 | cval = ((uint32_t)val * (uint32_t)(FTM1_MOD + 1)) >> analog_write_res;
C:\Users\james\AppData\Local\Temp\.arduinoIDE-unsaved2023113-15740-1eayfqr.42v4\sketch_dec3a\extra_code.ino:837:52: error: 'FTM0_MOD' was not declared in this scope
837 | cval = ((uint32_t)val * (uint32_t)(FTM0_MOD + 1)) >> analog_write_res;
C:\Users\james\AppData\Local\Temp\.arduinoIDE-unsaved2023113-15740-1eayfqr.42v4\sketch_dec3a\extra_code.ino: In function 'void analogWriteFrequency(uint8_t, float)':
C:\Users\james\AppData\Local\Temp\.arduinoIDE-unsaved2023113-15740-1eayfqr.42v4\sketch_dec3a\extra_code.ino:1018:33: error: 'F_TIMER' was not declared in this scope
1018 | if (frequency < (float)(F_TIMER >> 7) / 65536.0f) {
C:\Users\james\AppData\Local\Temp\.arduinoIDE-unsaved2023113-15740-1eayfqr.42v4\sketch_dec3a\extra_code.ino:1044:20: error: 'FTM1_CH0_PIN' was not declared in this scope
1044 | if (pin == FTM1_CH0_PIN || pin == FTM1_CH1_PIN) {
C:\Users\james\AppData\Local\Temp\.arduinoIDE-unsaved2023113-15740-1eayfqr.42v4\sketch_dec3a\extra_code.ino:1044:43: error: 'FTM1_CH1_PIN' was not declared in this scope
C:\Users\james\AppData\Local\Temp\.arduinoIDE-unsaved2023113-15740-1eayfqr.42v4\sketch_dec3a\extra_code.ino:1045:17: error: 'FTM1_SC' was not declared in this scope
1045 | FTM1_SC = 0;
C:\Users\james\AppData\Local\Temp\.arduinoIDE-unsaved2023113-15740-1eayfqr.42v4\sketch_dec3a\extra_code.ino:1046:17: error: 'FTM1_CNT' was not declared in this scope
1046 | FTM1_CNT = 0;
C:\Users\james\AppData\Local\Temp\.arduinoIDE-unsaved2023113-15740-1eayfqr.42v4\sketch_dec3a\extra_code.ino:1047:17: error: 'FTM1_MOD' was not declared in this scope
1047 | FTM1_MOD = mod;
C:\Users\james\AppData\Local\Temp\.arduinoIDE-unsaved2023113-15740-1eayfqr.42v4\sketch_dec3a\extra_code.ino:1048:27: error: 'FTM_SC_CLKS' was not declared in this scope
1048 | FTM1_SC = FTM_SC_CLKS(ftmClockSource) | FTM_SC_PS(prescale); //Use ftmClockSource instead of 1
C:\Users\james\AppData\Local\Temp\.arduinoIDE-unsaved2023113-15740-1eayfqr.42v4\sketch_dec3a\extra_code.ino:1048:57: error: 'FTM_SC_PS' was not declared in this scope
C:\Users\james\AppData\Local\Temp\.arduinoIDE-unsaved2023113-15740-1eayfqr.42v4\sketch_dec3a\extra_code.ino:1049:27: error: 'FTM0_CH0_PIN' was not declared in this scope
1049 | } else if (pin == FTM0_CH0_PIN || pin == FTM0_CH1_PIN
C:\Users\james\AppData\Local\Temp\.arduinoIDE-unsaved2023113-15740-1eayfqr.42v4\sketch_dec3a\extra_code.ino:1049:50: error: 'FTM0_CH1_PIN' was not declared in this scope
C:\Users\james\AppData\Local\Temp\.arduinoIDE-unsaved2023113-15740-1eayfqr.42v4\sketch_dec3a\extra_code.ino:1050:21: error: 'FTM0_CH2_PIN' was not declared in this scope
1050 | || pin == FTM0_CH2_PIN || pin == FTM0_CH3_PIN
C:\Users\james\AppData\Local\Temp\.arduinoIDE-unsaved2023113-15740-1eayfqr.42v4\sketch_dec3a\extra_code.ino:1050:44: error: 'FTM0_CH3_PIN' was not declared in this scope
C:\Users\james\AppData\Local\Temp\.arduinoIDE-unsaved2023113-15740-1eayfqr.42v4\sketch_dec3a\extra_code.ino:1051:21: error: 'FTM0_CH4_PIN' was not declared in this scope
1051 | || pin == FTM0_CH4_PIN || pin == FTM0_CH5_PIN
C:\Users\james\AppData\Local\Temp\.arduinoIDE-unsaved2023113-15740-1eayfqr.42v4\sketch_dec3a\extra_code.ino:1051:44: error: 'FTM0_CH5_PIN' was not declared in this scope
C:\Users\james\AppData\Local\Temp\.arduinoIDE-unsaved2023113-15740-1eayfqr.42v4\sketch_dec3a\extra_code.ino:1056:17: error: 'FTM0_SC' was not declared in this scope
1056 | FTM0_SC = 0;
C:\Users\james\AppData\Local\Temp\.arduinoIDE-unsaved2023113-15740-1eayfqr.42v4\sketch_dec3a\extra_code.ino:1057:17: error: 'FTM0_CNT' was not declared in this scope
1057 | FTM0_CNT = 0;
C:\Users\james\AppData\Local\Temp\.arduinoIDE-unsaved2023113-15740-1eayfqr.42v4\sketch_dec3a\extra_code.ino:1058:17: error: 'FTM0_MOD' was not declared in this scope
1058 | FTM0_MOD = mod;
C:\Users\james\AppData\Local\Temp\.arduinoIDE-unsaved2023113-15740-1eayfqr.42v4\sketch_dec3a\extra_code.ino:1059:27: error: 'FTM_SC_CLKS' was not declared in this scope
1059 | FTM0_SC = FTM_SC_CLKS(ftmClockSource) | FTM_SC_PS(prescale); //Use ftmClockSource instead of 1
C:\Users\james\AppData\Local\Temp\.arduinoIDE-unsaved2023113-15740-1eayfqr.42v4\sketch_dec3a\extra_code.ino:1059:57: error: 'FTM_SC_PS' was not declared in this scope
C:\Users\james\AppData\Local\Temp\.arduinoIDE-unsaved2023113-15740-1eayfqr.42v4\sketch_dec3a\extra_code.ino: In function 'void digitalWrite(uint8_t, uint8_t)':
C:\Users\james\AppData\Local\Temp\.arduinoIDE-unsaved2023113-15740-1eayfqr.42v4\sketch_dec3a\extra_code.ino:1116:37: error: 'PORT_PCR_PE' was not declared in this scope
1116 | *config |= (PORT_PCR_PE | PORT_PCR_PS);
C:\Users\james\AppData\Local\Temp\.arduinoIDE-unsaved2023113-15740-1eayfqr.42v4\sketch_dec3a\extra_code.ino:1116:51: error: 'PORT_PCR_PS' was not declared in this scope
C:\Users\james\AppData\Local\Temp\.arduinoIDE-unsaved2023113-15740-1eayfqr.42v4\sketch_dec3a\extra_code.ino:1120:38: error: 'PORT_PCR_PE' was not declared in this scope
1120 | *config &= ~(PORT_PCR_PE);
C:\Users\james\AppData\Local\Temp\.arduinoIDE-unsaved2023113-15740-1eayfqr.42v4\sketch_dec3a\extra_code.ino: In function 'void pinMode(uint8_t, uint8_t)':
C:\Users\james\AppData\Local\Temp\.arduinoIDE-unsaved2023113-15740-1eayfqr.42v4\sketch_dec3a\extra_code.ino:1152:27: error: 'PORT_PCR_SRE' was not declared in this scope
1152 | *config = PORT_PCR_SRE | PORT_PCR_DSE | PORT_PCR_MUX(1);
C:\Users\james\AppData\Local\Temp\.arduinoIDE-unsaved2023113-15740-1eayfqr.42v4\sketch_dec3a\extra_code.ino:1152:42: error: 'PORT_PCR_DSE' was not declared in this scope
C:\Users\james\AppData\Local\Temp\.arduinoIDE-unsaved2023113-15740-1eayfqr.42v4\sketch_dec3a\extra_code.ino:1152:57: error: 'PORT_PCR_MUX' was not declared in this scope
C:\Users\james\AppData\Local\Temp\.arduinoIDE-unsaved2023113-15740-1eayfqr.42v4\sketch_dec3a\extra_code.ino:1154:32: error: 'PORT_PCR_ODE' was not declared in this scope
1154 | *config |= PORT_PCR_ODE;
C:\Users\james\AppData\Local\Temp\.arduinoIDE-unsaved2023113-15740-1eayfqr.42v4\sketch_dec3a\extra_code.ino:1156:33: error: 'PORT_PCR_ODE' was not declared in this scope
1156 | *config &= ~PORT_PCR_ODE;
C:\Users\james\AppData\Local\Temp\.arduinoIDE-unsaved2023113-15740-1eayfqr.42v4\sketch_dec3a\extra_code.ino:1165:35: error: 'PORT_PCR_MUX' was not declared in this scope
1165 | *config = PORT_PCR_MUX(1);
C:\Users\james\AppData\Local\Temp\.arduinoIDE-unsaved2023113-15740-1eayfqr.42v4\sketch_dec3a\extra_code.ino:1167:35: error: 'PORT_PCR_MUX' was not declared in this scope
1167 | *config = PORT_PCR_MUX(1) | PORT_PCR_PE | PORT_PCR_PS;
C:\Users\james\AppData\Local\Temp\.arduinoIDE-unsaved2023113-15740-1eayfqr.42v4\sketch_dec3a\extra_code.ino:1167:53: error: 'PORT_PCR_PE' was not declared in this scope
C:\Users\james\AppData\Local\Temp\.arduinoIDE-unsaved2023113-15740-1eayfqr.42v4\sketch_dec3a\extra_code.ino:1167:67: error: 'PORT_PCR_PS' was not declared in this scope
C:\Users\james\AppData\Local\Temp\.arduinoIDE-unsaved2023113-15740-1eayfqr.42v4\sketch_dec3a\extra_code.ino:1169:35: error: 'PORT_PCR_MUX' was not declared in this scope
1169 | *config = PORT_PCR_MUX(1) | PORT_PCR_PE;
C:\Users\james\AppData\Local\Temp\.arduinoIDE-unsaved2023113-15740-1eayfqr.42v4\sketch_dec3a\extra_code.ino:1169:53: error: 'PORT_PCR_PE' was not declared in this scope
C:\Users\james\AppData\Local\Temp\.arduinoIDE-unsaved2023113-15740-1eayfqr.42v4\sketch_dec3a\extra_code.ino:144:13: warning: 'void dummy_isr()' defined but not used [-Wunused-function]
144 | static void dummy_isr() {};
exit status 1
Compilation error: 'ClkPin' was not declared in this scope
I am begging anyone here for help. Even a pointer in the right direction would be amazing!
