Im trying to get this code to work for my project but it's not compiling. Im new to coding so need a bit of help working out if anythings wrong. The code has been tested so not entirely sure why its not working on my sketch... any help would be greatly appreciated
teensybuttoner:110: error: 'myset_key6' was not declared in this scope
KeyFunction_t* keyList[] = {myset_key6, myset_key5, myset_key4, myset_key3, myset_key2, myset_key1};
teensybuttoner:110: error: 'myset_key5' was not declared in this scope
teensybuttoner:110: error: 'myset_key4' was not declared in this scope
teensybuttoner:110: error: 'myset_key3' was not declared in this scope
teensybuttoner:110: error: 'myset_key2' was not declared in this scope
teensybuttoner:110: error: 'myset_key1' was not declared in this scope
C:\Users\alexander\Documents\Arduino\teensybuttoner\teensybuttoner.ino: In function 'void setup()':
C:\Users\alexander\Documents\Arduino\teensybuttoner\teensybuttoner.ino:103:34: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
#define NUMBUTTONS sizeof(buttons)
C:\Users\alexander\Documents\Arduino\teensybuttoner\teensybuttoner.ino:135:21: note: in expansion of macro 'NUMBUTTONS'
for (int i=0; i < NUMBUTTONS; i++) {
C:\Users\alexander\Documents\Arduino\teensybuttoner\teensybuttoner.ino: In function 'void sendEscape()':
C:\Users\alexander\Documents\Arduino\teensybuttoner\teensybuttoner.ino:294:35: warning: large integer implicitly truncated to unsigned type [-Woverflow]
Keyboard.set_key1(ESCAPE_KEY);
exit status 1
3etamax:
I did try to post to code as described but it exceeded the 9000 character limit per post
In which case you can break it into a few pieces and post them individually (you probably have to wait an annoying 5 or 10 minutes between posts due to low post count) or attach the file to your post.
int keySlot = sizeof(keyList) / sizeof(KeyFunction_t*);
typedef void KeyFunction_t(uint8_t c);
#if OUTPUT_MODE == MODE_JOY
 int buttonActive[NUMBUTTONS];
#else
 KeyFunction_t* buttonActive[NUMBUTTONS];
#endif
I get a new error message further down:
TeensyButtoner:110: error: 'keyList' was not declared in this scope
TeensyButtoner:110: error: 'KeyFunction_t' was not declared in this scope
TeensyButtoner:110: error: expected primary-expression before ')' token
TeensyButtoner:111: error: 'KeyFunction_t' does not name a type
C:\Users\alexander\Documents\Teensy 2.0\TeensyButtoner-master\TeensyButtoner\TeensyButtoner.ino: In function 'void setup()':
C:\Users\alexander\Documents\Teensy 2.0\TeensyButtoner-master\TeensyButtoner\TeensyButtoner.ino:113:34: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
C:\Users\alexander\Documents\Teensy 2.0\TeensyButtoner-master\TeensyButtoner\TeensyButtoner.ino:145:21: note: in expansion of macro 'NUMBUTTONS'
C:\Users\alexander\Documents\Teensy 2.0\TeensyButtoner-master\TeensyButtoner\TeensyButtoner.ino: In function 'void sendEscape()':
C:\Users\alexander\Documents\Teensy 2.0\TeensyButtoner-master\TeensyButtoner\TeensyButtoner.ino:304:35: warning: large integer implicitly truncated to unsigned type [-Woverflow]
C:\Users\alexander\Documents\Teensy 2.0\TeensyButtoner-master\TeensyButtoner\TeensyButtoner.ino: In function 'void activateButton(byte)':
TeensyButtoner:328: error: 'keyList' was not declared in this scope
buttonActive[index] = keyList[keySlot]; //Associate the keySlot function pointer with the button
C:\Users\alexander\Documents\Teensy 2.0\TeensyButtoner-master\TeensyButtoner\TeensyButtoner.ino: In function 'void releaseButton(byte)':
TeensyButtoner:346: error: 'keyList' was not declared in this scope
keyList[keySlot] = buttonActive[index]; //retrieve the keySlot function pointer
exit status 1
The intention of Paul_S' suggestion was to move the below
void myset_key1(uint8_t c)
 Keyboard.set_key1(c);
void myset_key2(uint8_t c)
 Keyboard.set_key2(c);
void myset_key3(uint8_t c)
 Keyboard.set_key3(c);
void myset_key4(uint8_t c)
 Keyboard.set_key4(c);
void myset_key5(uint8_t c)
 Keyboard.set_key5(c);
void myset_key6(uint8_t c)
 Keyboard.set_key6(c);
to before the below part of your code
#else
#endif
In general, the compiler needs to know what functions 'look like' before it can use it; which parameters, what does it return). Your functions like myset_key6 are defined at the end of the code and hence the compiler does not know what they 'look like'. The IDE tries to be intelligent but failed in this case. Moving them up to before where they are used first solves the issue.
The alternative is to specify the prototypes of those functions before they are used in the code; in that case you can leave the functions themselves where they were and add the prototypes as shown below.
The above tells the compiler what your functions 'look like'; it does not define what they do though and hence you still need them at the end of your code.
This is the preferred way as you might want to split your code in future into multiple cpp files and prototypes allow for that.
