[Teensy LC] Joystick drifts, but no analog stick is connected
Hello, I was just testing out the Teensy LC and made a simple loop, in the Joystick mode, for pressing a button and releasing a button.
I've tested it out in games, if it would work (It did), but after few minutes the character just moved left. I looked in the "joy.cpl" file on windows (which is basiclly a file / programm where you can look up, if a button was pressed or not on a gamepad) and saw that the left analog stick was drifting.
Is there a fix to that driftig, do I need to buy a new Teensy or is there some other way?
Code:
const int ledPin = 13;
  pinMode(ledPin, OUTPUT);
  digitalWrite(ledPin, HIGH);
  Joystick.button(1, 1);
  Joystick.button(1, 0);
Results from "joy.cpl":
Teensy Setup:
Teensy (Teensy® LC or Arduino Official Store | Boards Shields Kits Accessories):
If I need to provied some more information, just ask
Thanks in advance!
The picture of the Teensy seems to be missing the Joystick, so where do you have the joystick connected ?
With floating inputs the results are dependent on the phase of the moon in relation to Mars. In other words it is unknown, can change and can be anywhere between 0 and VCC.
That's the confusig part, nowhere.
Like it drifts, even if no analog stick is connected
Why is it 'confusig' ?
The code you wrote expects a joystick to be connected.
Is it a surprise the code to read a joystick does not work correctly if there is no joystick connected ?
Maybe the best thing is to post a schematic, not a frizzy pictures showing exactly how you have wired it. Include links to technical information on all the hardware as well.
I'll try to connect a Joystick tomorrow and update my current status, like if it worked or not.
