And when pin 4 is connected to 100Khz pulse result is ok.
Without changing code even same sketch uploaded when i connected a 2Mhz wire to Teensy any pin
, output changes from 100khz to 138khz to 150khz.
So does this mean there is a first Teensy 3.5 that does sending
and you have a second Teensy 3.5 that read IN this serial data?
Or does the 2 MHz clocked signal come from a different source?
It would help a lot of you would post a hand-drawn picture that shows what kind of device is sending and what kind of device is receiving the serial data-stream.
You are working on an informatic project and what is most needed in an informatic project is: information
As you are working with a Teensy. Have you considered asking in the PCJR-Forums that are especcially about Teensy-microcontrollers?
This means you can configure an interrupt for the clock-signal with invoke interrupt on FALLING.
Inside the ISR check logic level of the SYNC-input and if SYNC-input is HIGH
bitshift the value of the databit into a variable
Are you able to make the EZCAD control card send a constant value?
If not do you have a second teensy that could act as a dummy for having under control what value you are sending?
As the approach is interrupt driven for testing the read-in logic to work right you could use a lower-frequency for the clock
Yes exactly and i am on the same page but when i configure interrupt on clock falling edge it goes slow down when I digitalRead(syncPin) or digitalReadFast(sync) for checking sync pin is high/low.
Its teensy 3.5 slowness need other fast development board than teensy 3.5 ?
I don't understand what you wanto to say with that. To me it seems that your english-knowledge is limited. If this is true write your answer in a texteditor in your native language and then do copy & paste and let do google translate the translation to english.
If you do any kind of serial printing inside an ISR serial printing is slowing down !
Again: You are working on an informatic project and most important in an informatic project is sufficient information.
In this case this sufficient information is your complete sketch that you used to test it.
If you want any kind of information that your reading in worked correct it must be done in a different way than serial printing inside the ISR
You could use a boolean flag to read in a single 20bit dataword and after reading in that single dataword set the flag-variable to true and then do the printing outside the ISR
That 85 cycles is on an AVR to save the state of the processor and jump to the interrupt, run that and then restore and jump back. What is in between, make as fast as you can.
Another way is to poll with the least overhead you can manage. See what kind of average frequency you can get.
Both ways have to read and at least store the data as well.
With a 180MHz Teensy 3.5, there should be a nanos() function even if the grain is 10's or 100 nanos per tick just to time sub-microsec events.
Example of polling on an AVR, I debounce button pins by reading them twice a milli into a byte that gets x2 before the read, a 0 or 1, is added. The value in binary shows 4 millis worth of pin state history. The compares are built in, the timing is when to read, less code = faster.
When the history byte shown in binary and the pin is INPUT_PULLUP,
10000000 is button up-down transition detected and stable.
00000001 is the down-up, the release.
One function in void loop() does the reads and the other functions compare the history to their trigger value to run or not in loop and loop keeps looping the driving wheel of all the functions.
If you collect digital data at regular intervals you can store it as bits.
If the interval is small compared to your timing tolerance, should be good.
@GoForSmoke Thanks for your reply and good suggestions.
My task is not to store or serial print , but i will test as you said.
But my actual task is to convert a 20 bit binary (2 Mhz Clock) to 16 bit binary (2MHz clock) and write it on other pin in real time. No storing no serial print needed.
Finaly this 16 bit with will use as Input of 16bit DAC for real time analog out.
I think your only hope of making that work would be to write the whole thing in assembler, using NO Arduino library calls of any kind, and the processor will be unable to do ANYTHING else. Even then, it could be a stretch. You will be fielding an interrupt at least EVERY 60 CPU clock cycles.
Just an idea here … it would take a lot of work to determine feasibility. Perhaps your input signal could be made to look enough like SPI to use the Teensy's hardware SPI interface. The Teensy would have to operate in SPI Slave mode. You'd probably need some external logic to make the Sync signal act as Slave Select. Because SPI operates on bytes, I'd to read 5 bytes (40 bits) at a time. That equals two of your data words. Two other thoughts that might help … use DMA to transfer from the Teensy's SPI hardware to memory … use ping-pong buffer techniques.
Well, that's a sketchy outline. The rest, as they say, is left as an exercise for the student.
