Hello,
I've been trying to measure the magnetic field of the Earth with the RM3100 Magnetometer and a Teensy 4.1. I started testing it with an Arduino Uno which worked completely, but when I port everything to the Teensy it works 50% of the time. One half of the time it will measure it twice, then it will loop into failing. The other half it just starts that way.
Here is my code:
#include <SPI.h> //communicate with SPI devices - LoRa and Magnetometer
#define PIN_DRDY 28 //Set pin D9 to be the Data Ready Pin
#define PIN_CS 27 //Chip Select (SS) is set to Pin 10
#define RM3100_REVID_REG 0x36 // Hexadecimal address for the Revid internal register
#define RM3100_POLL_REG 0x00 // Hexadecimal address for the Poll internal register
#define RM3100_CMM_REG 0x01 // Hexadecimal address for the Continuous Measurement Mode internal register
#define RM3100_STATUS_REG 0x34 // Hexadecimal address for the Status internal register
#define RM3100_CCX1_REG 0x04 // Hexadecimal address for the Cycle Count X1 internal register
#define RM3100_CCX0_REG 0x05 // Hexadecimal address for the Cycle Count X0 internal register
#define initialCC 200 // Set the cycle count
#define singleMode 0 //0 = use continuous measurement mode; 1 = use single measurement mode
#define useDRDYPin 0
uint8_t revid;
uint16_t cycleCount;
float gain;
uint8_t readReg(uint8_t addr){
uint8_t data = 0;
digitalWrite(PIN_CS, LOW);
delay(100);
SPI.transfer(addr | 0x80); //OR with 0x80 to make first bit(read/write bit) high for read
data = SPI.transfer(0);
digitalWrite(PIN_CS, HIGH);
return data;
//addr is the 7 bit (No r/w bit) value of the internal register's address, data is 8 bit data being written
void writeReg(uint8_t addr, uint8_t data){
delay(100);
SPI.transfer(addr & 0x7F); //AND with 0x7F to make first bit(read/write bit) low for write
SPI.transfer(data);
//newCC is the new cycle count value (16 bits) to change the data acquisition
void changeCycleCount(uint16_t newCC){
uint8_t CCMSB = (newCC & 0xFF00) >> 8; //get the most significant byte
uint8_t CCLSB = newCC & 0xFF; //get the least significant byte
delay(100);
SPI.transfer(RM3100_CCX1_REG & 0x7F); //AND with 0x7F to make first bit(read/write bit) low for write
SPI.transfer(CCMSB); //write new cycle count to ccx1
SPI.transfer(CCLSB); //write new cycle count to ccx0
SPI.transfer(CCMSB); //write new cycle count to ccy1
SPI.transfer(CCLSB); //write new cycle count to ccy0
SPI.transfer(CCMSB); //write new cycle count to ccz1
SPI.transfer(CCLSB); //write new cycle count to ccz0
void setup(){
//Wire.begin();
pinMode(PIN_DRDY, INPUT);
pinMode(PIN_CS, OUTPUT);
SPI.begin(); // Initiate the SPI library
SPI.beginTransaction(SPISettings(1000000, MSBFIRST, SPI_MODE0));
//myservo.attach(servoPin);
delay(100);
revid = readReg(RM3100_REVID_REG);
Serial.print("REVID ID = 0x"); //REVID ID should be 0x22
Serial.println(revid, HEX);
changeCycleCount(initialCC); //change the cycle count; default = 200 (lower cycle count = higher data rates but lower resolution)
cycleCount = readReg(RM3100_CCX1_REG);
cycleCount = (cycleCount << 8) | readReg(RM3100_CCX0_REG);
Serial.print("Cycle Counts = "); //display cycle count
Serial.println(cycleCount);
gain = (0.3671 * (float)cycleCount) + 1.5; //linear equation to calculate the gain from cycle count
Serial.print("Gain = "); //display gain; default gain should be around 75 for the default cycle count of 200
Serial.println(gain);
if (singleMode){
//set up single measurement mode
writeReg(RM3100_CMM_REG, 0);
writeReg(RM3100_POLL_REG, 0x70);
else{
// Enable transmission to take continuous measurement with Alarm functions off
writeReg(RM3100_CMM_REG, 0x79);
void loop(){
long x = 0;
long y = 0;
long z = 0;
uint8_t x2,x1,x0,y2,y1,y0,z2,z1,z0;
//Start of Mag
while((readReg(RM3100_STATUS_REG) & 0x80) != 0x80) {
Serial.println("Not Working"); //This is the line that is repeating
delay(1);
//read measurements
delay(100);
SPI.transfer(0xA4);
x2 = SPI.transfer(0xA5);
x1 = SPI.transfer(0xA6);
x0 = SPI.transfer(0xA7);
y2 = SPI.transfer(0xA8);
y1 = SPI.transfer(0xA9);
y0 = SPI.transfer(0xAA);
z2 = SPI.transfer(0xAB);
z1 = SPI.transfer(0xAC);
z0 = SPI.transfer(0);
//special bit manipulation since there is not a 24 bit signed int data type
if (x2 & 0x80){
x = 0xFF;
if (y2 & 0x80){
y = 0xFF;
if (z2 & 0x80){
z = 0xFF;
//format results into single 32 bit signed value
x = (x * 256 * 256 * 256) | (int32_t)(x2) * 256 * 256 | (uint16_t)(x1) * 256 | x0;
y = (y * 256 * 256 * 256) | (int32_t)(y2) * 256 * 256 | (uint16_t)(y1) * 256 | y0;
z = (z * 256 * 256 * 256) | (int32_t)(z2) * 256 * 256 | (uint16_t)(z1) * 256 | z0;
//calculate magnitude of results
double uT = sqrt(pow(((float)(x)/gain),2) + pow(((float)(y)/gain),2)+ pow(((float)(z)/gain),2));
//display results
Serial.print("Data in counts:");
Serial.print(" X:");
Serial.print(x);
Serial.print(" Y:");
Serial.print(y);
Serial.print(" Z:");
Serial.println(z);
Serial.print("Data in microTesla(uT):");
Serial.print((float)(x)/gain);
Serial.print((float)(y)/gain);
Serial.println((float)(z)/gain);
//Magnitude should be around 45 uT (+/- 15 uT)
Serial.print("Magnitude(uT):");
Serial.println(uT);
delay(5000);
Any help would be greatly appreciated.
