telegram bot.h library has issue how do i fix it?
Hi i need help with my coding, there is some issues with the TelegramBot.h library it keeps having an error. These are my codes and errors that occurred. URGENT
#include <ESP8266WiFi.h>
#include <WiFiClientSecure.h>
#include <TelegramBot.h>
#define LED 1 //led pin number
// Initialize Wifi connection to the router
const char* ssid = "xxxxx";
const char* password = "yyyyy";
// Initialize Telegram BOT
const char BotToken[] = "xxxxxxxxx";
WiFiClientSecure net_ssl;
TelegramBot bot (BotToken, net_ssl);
// the number of the LED pin
while (!Serial) {} //Start running when the serial is open
delay(3000);
// attempt to connect to Wifi network:
Serial.print("Connecting Wifi: ");
Serial.println(ssid);
while (WiFi.begin(ssid, password) != WL_CONNECTED)
Serial.print(".");
Serial.println("");
Serial.println("WiFi connected");
bot.begin();
pinMode(LED, OUTPUT);
message m = bot.getUpdates(); // Read new messages
if (m.text.equals("on"))
digitalWrite(LED, 1);
bot.sendMessage(m.chat_id, "The Led is now ON");
else if (m.text.equals("off"))
digitalWrite(LED, 0);
bot.sendMessage(m.chat_id, "The Led is now OFF");
These are the errors that occurred:
C:\Users\165298B\Documents\Arduino\libraries\TelegramBot\src\TelegramBot.cpp: In member function 'message TelegramBot::getUpdates()':
C:\Users\165298B\Documents\Arduino\libraries\TelegramBot\src\TelegramBot.cpp:39:4: error: 'StaticJsonBuffer' was not declared in this scope
StaticJsonBuffer<JSON_BUFF_SIZE> jsonBuffer;
C:\Users\Documents\Arduino\libraries\TelegramBot\src\TelegramBot.cpp:39:37: error: 'jsonBuffer' was not declared in this scope
C:\Users\Documents\Arduino\libraries\TelegramBot\src\TelegramBot.cpp:44:12: error: 'class ArduinoJson650_0_0::JsonObject' has no member named 'success'
if(root.success()){
C:\Users\Documents\Arduino\libraries\TelegramBot\src\TelegramBot.cpp: In member function 'String TelegramBot::sendMessage(String, String)':
C:\Users\Documents\Arduino\libraries\TelegramBot\src\TelegramBot.cpp:87:3: error: 'StaticJsonBuffer' was not declared in this scope
C:\Users\Documents\Arduino\libraries\TelegramBot\src\TelegramBot.cpp:87:36: error: 'jsonBuffer' was not declared in this scope
C:\Users\Documents\Arduino\libraries\TelegramBot\src\TelegramBot.cpp:93:8: error: 'class ArduinoJson650_0_0::JsonObject' has no member named 'printTo'
buff.printTo(msg);
C:\Users\Documents\Arduino\libraries\TelegramBot\src\TelegramBot.cpp: In member function 'String TelegramBot::sendMessage(String, String, TelegramKeyboard&, bool, bool)':
C:\Users\Documents\Arduino\libraries\TelegramBot\src\TelegramBot.cpp:102:3: error: 'StaticJsonBuffer' was not declared in this scope
C:\Users\Documents\Arduino\libraries\TelegramBot\src\TelegramBot.cpp:102:36: error: 'jsonBuffer' was not declared in this scope
C:\Users\165298B\Documents\Arduino\libraries\TelegramBot\src\TelegramBot.cpp:107:68: error: invalid initialization of non-const reference of type 'ArduinoJson650_0_0::JsonObject&' from an rvalue of type 'ArduinoJson650_0_0::JsonObject'
JsonObject& reply_markup = buff.createNestedObject("reply_markup");
C:\Users\Documents\Arduino\libraries\TelegramBot\src\TelegramBot.cpp:108:66: error: invalid initialization of non-const reference of type 'ArduinoJson650_0_0::JsonArray&' from an rvalue of type 'ArduinoJson650_0_0::JsonArray'
JsonArray& keyboard = reply_markup.createNestedArray("keyboard");
C:\Users\Documents\Arduino\libraries\TelegramBot\src\TelegramBot.cpp:111:48: error: invalid initialization of non-const reference of type 'ArduinoJson650_0_0::JsonArray&' from an rvalue of type 'ArduinoJson650_0_0::JsonArray'
JsonArray& row = keyboard.createNestedArray();
C:\Users\Documents\Arduino\libraries\TelegramBot\src\TelegramBot.cpp:122:8: error: 'class ArduinoJson650_0_0::JsonObject' has no member named 'printTo'
buff.printTo(msg);
exit status 1
Error compiling for board Generic ESP8266 Module.
Please use code tags (</> button on the toolbar) when you post code or warning/error messages. The reason is that the forum software can interpret parts of your code as markup, leading to confusion, wasted time, and a reduced chance for you to get help with your problem. This will also make it easier to read your code and to copy it to the IDE or editor. If your browser doesn't show the posting toolbar then you can just manually add the code tags:
[code]``[color=blue]// your code is here[/color]``[/code]
Using code tags and other important information is explained in the How to use this forum post. Please read it.
Please always do a Tools > Auto Format on your code before posting it. This will make it easier for you to spot bugs and make it easier for us to read. If you're using the Arduino Web Editor you will not have access to this useful tool but it's still unacceptable to post poorly formatted code. I recommend you to use the standard IDE instead.
The explanation of the error and the solution is explained in the ArduinoJson library's documentation:
