Telegram Bot Library
Good day All,
I m using with Arduino Mega and Wifi Shield . I want send text message to Telegram from the Arduino.
I have found the Telegram Bot library (Telegram Bot Library - Arduino Project Hub) , but seems like its only for WiFi101 shield! And I replaced library WiFi101 with WiFi. WiFi connection was successfully, but the message wasnt sent to Telegram(on the serial monitor :"no socket available")
Any help would be much appreciated.
Thank you in advance!
Hi, my good friend. I have the same problem, I work with arduino wifi shield and the serial monitor print me: no socket available .I can help me, if you already solved please. Thank you.
