Telegram, Error sending the message
Good day to everyone,
currently I'm working on Arduino project for University. In particular, I'm developing an environment which consists in Arduino Uno R4 Wifi, 2 led, a force sensor and a Telegram bot. Basically, the force sensor detects a force and the first led power up; then, when the force is detected longer than 10 sec, the second led light up. In this case, I want to receive a notification from my Telegram bot on my smartphone. The problem is that Arduino doesn't send any message (or Telegram doesn't receive?). Belove the sketch I am using
#include <WiFiS3.h>
#include <WiFiSSLClient.h>
#include <UniversalTelegramBot.h>
const int pinPressureSensor = A0;
const int pinGreenLED = 11;
const int pinRedLED = 12;
// Wi-Fi credentials
const char* ssid = "xxxxxxxxxxxxxx";
const char* password = "xxxxxxxxx";
// Telegram bot data
#define BOT_TOKEN "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
#define CHAT_ID "xxxxxxxxxxxx"
WiFiClient client;
UniversalTelegramBot bot(BOT_TOKEN, client);
unsigned long startTime = 0;
bool forceDetected = false;
  pinMode(pinGreenLED, OUTPUT);
  pinMode(pinRedLED, OUTPUT);
  digitalWrite(pinGreenLED, LOW);
  digitalWrite(pinRedLED, LOW);
  Serial.println("Connecting to Wi-Fi...");
  WiFi.begin(ssid, password);
  Serial.println("Connected to Wi-Fi!");
  int sensorValue = analogRead(pinPressureSensor);
  Serial.println(sensorValue);
  if (sensorValue > 1) {
    if (!forceDetected) {
      forceDetected = true;
      startTime = millis();
      digitalWrite(pinGreenLED, HIGH); // Turn on the green LED
      if (millis() - startTime >= 10000) {  // After 10 seconds
        digitalWrite(pinGreenLED, LOW);  // Turn off the green LED
        digitalWrite(pinRedLED, HIGH);   // Turn on the red LED
        // Send the message to Telegram
Serial.println("Sending message to Telegram...");
bool result = bot.sendMessage(CHAT_ID, "TEST", "");
if (!result) {
            Serial.println("Error sending the message. Check the parameters.");
    digitalWrite(pinRedLED, LOW);     // Turn off the red LED
  delay(100);  // Stabilize sensor readings
The code is working regarding the sensor and led, but fails in sending the notification via Telegram. I've already created my bot and start a conversation, I also written some code in Pyhton to better customize it. Any help in this matter is welcome. I thank you in advance.
Regards
have you tested sending "hello world" to your Telegram bot?
Honestly no. I've tried with a simple "TEST" message like in the sketch bool result = bot.sendMessage(CHAT_ID, "TEST", "");. Doing this I receive back the error message that I printed, meaning that the the message wasn't sent.
you should be able to send a msg in setup() without any other code. you need to get the telegram code to work before expecting the force detection msg. (i know this sounds obvious)
Telegram bot was operative (bot code written in Python was running in background), if are you referring at this. Otherwise, I don't understand what you referring to :frowning:
you need to get Telegram to work on your Arduino before you try using it with other things (force detection).
don't understand why you mention Python. Python doesn' run on Arduino
Yes, I mentioned Python only because I "customized" my both to answer some specific questions. But this has nothing to do with Arduino. What you mean to get Telegram to work on my Arduino?
on what ever board you're using. gessing an esp board
Yes, I'm usinging Arduino Uno R4 Wifi. Do I need additional components?
no
find some example code that does this
Ok. Understand, I will try with a simple code like this to verify if the system works.
  Serial.println("Connected to Wi-Fi");
   bot.sendMessage(CHAT_ID, "Hello World", "");
yes. if that doesn't work, you need to figure out what is missing.
did you see the "Hello World" example in Telegram Bot Library. are you missing bot.begin();?
Solve!! At the end the error was in the code instead of
WiFiClient client;
I put
WiFiSSLCClient client;
Now I receive the notifications on my Telegram bot.
