Telegram with modemcu
Hello, I'm using TELEGRAM to track the GPS location of a modem device, which is connected to a role and ADXL345 sensor. The code works perfectly on one of the modems I have. I recently purchased 2 new modems, but they are not working. The code and everything else is identical. When I load the code that works on the first modem onto the new ones, there's no issue. However, there's a problem with the other two.
I've monitored the serial ports and it sets up a Wi-Fi converter. It can find the sensors, but it doesn't communicate through Telegram. I've tried turning off other channels to isolate the issue and ensure Telegram is the only one working, but it still doesn't work.
Can you please help me with this?"
You might want to read and understand this first.
https://forum.arduino.cc/t/how-to-get-the-best-out-of-this-forum/1111649
