Telemetre laser sensor for measuring distance to a single spot?
Hello!
I need a scanner with the lowest angle detection posible, just for measuring distance from the sensor to a single spot as a laser pointer, and not to any object arround.
The distance i wan't to measure goes from 50 cm to 3m.
I have been looking, but i have not seen anything without a open angle range.
¿Is that posible?
THank you!!
You must have a specification for how big of a spot you want. 1cm diameter, 8cm diameter? Also specify the distance at which you want the spot to be that small. It will get bigger at longer ranges.
MorganS:
Thanks MorganS.
1cm diameter or less it would be perfect, until the 3 meters distance. I don't need any measure further than 3m, so if the diameter increases at 4, 5 or 10 m it's not a problem.
Thank you!
You'll have to look for lasers - ultrasound is definitely out as it produces a far too big spot.
Will the point you try to measure be any special, such as a reflector?
Also wondering, how are you planning to keep your measuring device pointed this accurately?
