Telemetry for analysis
I have a robot running an Arduino Uno R3, the ethernet shield, and a RobotOpen shield. I was thinking of having the robot save data such as voltage over time and speed over time, and possibly current over time to the SD card slot on the ethernet shield (with a 1 gb card of course) for later analysis on my computer. But im not sure how to A)have it read and write the data to the card and B)not sure how to have the data in a format that I can read. This is the existing code for a Tank Drive style setup:
#include <SPI.h>
#include <Ethernet.h>
#include <RobotOpen.h>
/* I/O Setup */
USBJoystick usb1(‘0’); // Assign the logitech USBJoystick object to bundle 0
/* Initiate comms */
RobotOpen.begin();
/* This is your primary robot loop - all of your code
  • should live here that allows the robot to operate
    void enabled() {
    // Constantly update PWM values with joystick values
    RobotOpen.setPWM(SIDECAR_PWM1, usb1.makePWM(ANALOG_LEFTY, INVERT));
    RobotOpen.setPWM(SIDECAR_PWM2, usb1.makePWM(ANALOG_RIGHTY, INVERT));
/* This is called while the robot is disabled
  • You must make sure to set all of your outputs
  • to safe/disable values here
    void disabled() {
    // PWMs are automatically disabled
/* This loop ALWAYS runs - only place code here that can run during a disabled state
  • This is also a good spot to put driver station publish code
  • You can use either publishAnalog, publishDigital, publishByte, publishShort, or publishLong
  • Specify a bundle ID with a single character (a-z, A-Z, 0-9) - Just make sure not to use the same twice!
    void timedtasks() {
    RobotOpen.publishAnalog(ANALOG0, ‘A’); // Bundle A
    RobotOpen.publishAnalog(ANALOG1, ‘B’); // Bundle B
    RobotOpen.publishAnalog(ANALOG2, ‘C’); // Bundle C
    RobotOpen.publishAnalog(ANALOG3, ‘D’); // Bundle D
    RobotOpen.publishAnalog(ANALOG4, ‘E’); // Bundle E
    RobotOpen.publishAnalog(ANALOG5, ‘F’); // Bundle F
/* This is the main program loop that keeps comms operational
  • There’s no need to touch anything here!!!
    RobotOpen.pollDS();
    if (RobotOpen.enabled())
    enabled();
    disabled();
    timedtasks();
    RobotOpen.outgoingDS();
So where would I insert a code set for data capturing and how wold that be set up? My dead line is the 26th since this is for a team project so all help is appreciated
What is "it" that will be reading the data? What data?
Have you looked at any of the examples that come with the SD library?
What formats can you read? Save the data as text and read it as text.
Without the code tags...
