Teleop Module for Tetrix Prizm Pro(esp32s3 dev module) not working
When I import the library for the teleop module in combination with the tetrix prizm pro library to control my robot with a ps4 controller it causes an error:
/var/run/arduino/custom-libraries/TETRIX TELE-OP/TELEOP.cpp:9:10: fatal error: avr/wdt.h: No such file or directory
#include <avr/wdt.h>
compilation terminated.
I do not know what to make of this error code, here is my code, it is a sample code that I made to control forward and backward movements of a DC motor with a ps4 controller :
#include <TELEOP.h>
#include <PRIZM_PRO.h>
#include <notes.h>
#include <pixelPatterns.h>
#include <soundEffects.h>
PRIZM prizm;
PS4 ps4;
 prizm.PrizmBegin();
  prizm.setMotorInvert(2,1);
  prizm.setMotorInvert(3,1);
  ps4.getPS4();
  if(ps4.Button(UP)){
    prizm.setMotorPower(1,100);
    prizm.setMotorPower(2,100);
    prizm.setMotorPower(3,100);
    prizm.setMotorPower(4,100);
  if(ps4.Button(DOWN)){
    prizm.setMotorPower(1,-100);
    prizm.setMotorPower(2,-100);
    prizm.setMotorPower(3,-100);
    prizm.setMotorPower(4,-100);
  else{
    prizm.setMotorPower(1,0);
    prizm.setMotorPower(2,0);
    prizm.setMotorPower(3,0);
    prizm.setMotorPower(4,0);
You need to download and install the avr/wdt.h library. avr-libc/avr-libc/include/avr/wdt.h at master · vancegroup-mirrors/avr-libc · GitHub
When I download the Library it downloads as a file called avr-libc-master.zip and when I import it into arduino there is an error for an invalid library
Will only work on AVR boards, so the first question:
What board to you use?
esp32s3 dev module
you need to find an equivalent lib for ESP32
I solved the issue. It turns out that I downloaded the teleop library before the new tetrix prizm pro came out so I just needed to delete the library and download the new version. Thanks everyone for the help.
