Telling if characters in a string are numbers
I’m trying to make a RPN calculator out of an arduino. I have things where they split up the expression 1 2 3 4 + into different number/ commands to add to the stack. I need to differentiate between numbers (to add to the stack) and commands (to manipulate the stack)
Here’s my
 #include <StackList.h>
StackList <int> stack;
String work;
String readString;
  while (Serial.available()) {
    delay(10);
    char c = Serial.read();  //gets one byte from serial buffer
    readString += c;
  if (readString.length() >0) {
    while(readString.length()!=0) {
      readString.trim();                                        //Just in case
      readString.concat(' ');                                   //so the next function can work for the last argument
      work=readString.substring(0,readString.indexOf(' '));     //finds the data and operations
      if(work[0]=='0'||'1'||'2'||'3'||'4'||'5'||'6'||'7'||'8'||'9') {
        Serial.println(work);        //output of the equation
      readString=readString.substring(readString.indexOf(' ')); //removes the used argument
      readString=readString.trim();                             //removes white space at the beginning and end
Any help would be greatly appriciated.
Thanks,
Isaac
This…
…doesn’t do what you want or expect. Try this instead…
      if ( (work[0] >= '0') && (work[0] <= '9') ) {
You should really use one of the standard functions such as isdigit(x) in ctype.h for this.
And if this returns success, read it straight into a numeric variable (rather than a string) with something like
int a=Serial.read()-'0'
For multi-digit numbers (assuming you are using the space character as your separator), you'd need a Serial.peek () to see if you have another digit still to come.
As a matter of curiosity, how do you deal with negative numbers in RPN?
Thanks Andy. working as expected.
Code: int a=Serial.read()-'0'
Right now I'm just using the serial for simplicity's sake. I'm going to use a keypad and glcd in the future, so I'll use atoi() or .toInt(). For negative numbers I'll use:
isdigit(work[0]) || work[0]=='-'  && isdigit(work[1])
For negative numbers I'll use: Code: isdigit(work[0]) || work[0]=='-' && isdigit(work[1])
argh sorry djc. I'm running low on sleep (staying up coding :) ) but on calculators like the hp48 you use 100 neg which negates the number. It is the hp48 that inspired me to write this program.
