Temboo Error - RowData and SpreadsheetTitle are required
Hi all
Not sure if somebody can help
Im trying to achieve the following
Im using the following code - however when its run I get the following error
"An input error has occurred. RowData and SpreadsheetTitle are required - The error occurred in the Stop (Missing request parameters) step."
Heres the code - can anybody see any issues with it - driving me mad
// Include required libraries
#include <Bridge.h>
#include <Temboo.h>
#include <TembooCoAPEdgeDevice.h>
#include <TembooMQTTEdgeDevice.h>
#include <Process.h>
#include <Wire.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_BMP085_U.h>
// Contains Temboo account information
#include "TembooAccount.h"
// Variables
int lightLevel;
float humidity;
float temperature;
unsigned long time;
// Process to get the measurement time
Process date;
// Declare functions
void runAppendRow(float humidity, int lightLevel,
  float pressure, float temperature, float altitude);
// Your Google Docs data
const String GOOGLE_CLIENT_ID = "796719215272-c8**********************";
const String GOOGLE_CLIENT_SECRET = "P*******************";
const String GOOGLE_REFRESH_TOKEN = "1/4Ft***********************************";
const String SPREADSHEET_TITLE = "****Arduino";
#include "DHT.h"
// DHT11 sensor pins
#define DHTPIN 8
#define DHTTYPE DHT22
// DHT & BMP instances
DHT dht(DHTPIN, DHTTYPE);
Adafruit_BMP085_Unified bmp = Adafruit_BMP085_Unified(10085);
// Debug mode ?
boolean debug_mode = true;
  // Start Serial
  if (debug_mode == true){
    delay(4000);
    while(!Serial);
  // Initialize DHT sensor
  dht.begin();
  // Start bridge
  Bridge.begin();
  // Start date process
  time = millis();
  if (!date.running())  {
    date.begin("date");
    date.addParameter("+%D-%T");
    date.run();
    Serial.println("Setup complete. Waiting for sensor input...\n");
  // Initialise the sensor
  if(!bmp.begin())
    while(1);
  // Measure the humidity & temperature
  humidity = dht.readHumidity();
  // Measure light level
  int lightLevel = analogRead(A0);
  // Measure pressure & temperature from BMP sensor
  sensors_event_t event;
  bmp.getEvent(&event);
  float pressure = event.pressure;
   bmp.getTemperature(&temperature);
   float seaLevelPressure = SENSORS_PRESSURE_SEALEVELHPA;
   float altitude;
   altitude = bmp.pressureToAltitude(seaLevelPressure,
                                        event.pressure,
                                        temperature);
    Serial.println("\nCalling the AppendRow Choreo...");
  // Append data to Google Docs sheet
  runAppendRow(humidity, lightLevel, pressure, temperature, altitude);
  // Repeat every 10 minutes
  delay(600000);
// Function to add data to Google Docs
  float pressure, float temperature, float altitude) {
  TembooChoreo AppendRowChoreo;
  // Invoke the Temboo client
  AppendRowChoreo.begin();
  // Set Temboo account credentials
  AppendRowChoreo.setAccountName(TEMBOO_ACCOUNT);
  AppendRowChoreo.setAppKeyName(TEMBOO_APP_KEY_NAME);
  AppendRowChoreo.setAppKey(TEMBOO_APP_KEY);
  // Identify the Choreo to run
  AppendRowChoreo.setChoreo("/Library/Google/Spreadsheets/AppendRow");
  // your Google Client ID
  AppendRowChoreo.addInput("ClientID", GOOGLE_CLIENT_ID);
  // your Google Client Secret
  AppendRowChoreo.addInput("ClientSecret", GOOGLE_CLIENT_SECRET);
  // your Google Refresh Token
  AppendRowChoreo.addInput("RefreshToken", GOOGLE_REFRESH_TOKEN);
  // the title of the spreadsheet you want to append to
  AppendRowChoreo.addInput("SpreadsheetTitle", SPREADSHEET_TITLE);
  // Restart the date process:
    date.begin("date");
    date.run();
  // Get date
  String timeString = date.readString();
  // Format data
  String data = "";
  data = data + timeString + "," +
  String(humidity) + "," +
  String(lightLevel) + "," +
  String(pressure) + "," +
  String(temperature) + "," +
  String(altitude);
  // Set Choreo inputs
  AppendRowChoreo.addInput("RowData", data);
  // Run the Choreo
  unsigned int returnCode = AppendRowChoreo.run();
  // A return code of zero means everything worked
  if (returnCode == 0) {
      Serial.println("Completed execution of the AppendRow Choreo.\n");
    // A non-zero return code means there was an error
    // Read and print the error message
    while (AppendRowChoreo.available()) {
      char c = AppendRowChoreo.read();
      if (debug_mode == true){ Serial.print(c); }
    if (debug_mode == true){ Serial.println(); }
  AppendRowChoreo.close();
Hi there.
I have exactly the same issues (and error msg) with a correct code and it appears to be linked to problems of dynamical RAM which causes the Temboo data to get overwritten and corrupted (your code / data maybe correct, your Temboo & Google credentials ok, and you can still have this kind of problem just because there is not enough dyn. RAM available on the Yun). Hope it helps.
Jeff
Hi there, I work for Temboo.
As NiceAirProject said, it sounds like you may be running into a memory issue. You could look at using a profile for your Google Spreadsheet inputs. A profile allows you to simply reference your inputs from your sketch without including all of the String data that consumes memory. You can learn more about that approach here:
You can also free up some memory by putting the inputs that don't change (your Temboo credentials, your Google credentials, your output filter specifications, the Choreo to run) into a settings file on a micro SD card, as described here:
If you have any questions, feel free to contact us at Contact | Temboo - we're always happy to help.
