Hi guys, I'm trying to interface a pump that will be controlled via the PID library and a temp probe.
The pump details are as follows;
MOTOR
12V Brushless
OPERATING VOLTAGE
9V DC to 15V DC
MAX CURRENT
1.3 Amps
FLOWRATE @ 10 kpa
15 L/min (4 gal / min)
OPERATING TEMP
-40° to 120° DegC
PUMP DESIGN
Recirculating Centrifugal
So I figure I will need something like the following;
Would something like a NPN TIP31A be suitable ?
Does the design look sane ? this is pretty much my first Arduino project.
Yeah, I was a bit confused by that “brushless” part too. Did you hook up 12V to the motor just to try it at some point? If it just started turning then it’s not brushless and your circuit should be OK (except I would add some series resistance to the gate if the ATmega168 board doesn’t already have some to limit current from the ATmega168 pin).
If the motor doesn’t turn with 12V directly applied to its terminals…you have a slightly more complicated problem on your hands.
I am considering adding thermatic fan control to the circuit, easy enough, my question is regarding the best way to switch the fan.
The fans I am looking at are 5A@12VDC, Typically they are controlled via a standard automotive relay, I would like to avoid having two components and just wire them in directly in some fashion.
Would an optocoupler, solid state relay or transistor be a potential option or am I just better off with a plain old relay ?
Again a logic level MOSFET is the simplest method. Just make sure it’s rated for the total current of the attached loads and research if and how big a heat sink you may need for the MOSFET.
One thing I would recommend when using a MOSFET that switches a voltage that is other then the internal Arduino 5vdc or Vin pins and that is to add a resistor from the MOSFET gate to ground, 10K ohm should be fine. A ‘floating’ MOSFET gate can cause problems in some cases. This will insure that the MOSFET will stay off if you power down the Arduino without powering down the higher switched voltage that the MOSFET is controlling. Otherwise it’s possible for the switched device, say a motor will turn on until the Arduino is powered up and sets it’s I/O pin to output mode and low output. That make sense?
