I wrote the attached sketch. When I run the program 'firstled' blinks. I heated up the sensor with a hair dryer but it does not cause the remaining led's to light up.
Do I have an issue with not converting temperature to Celsius? do I have an error in my code?
By the way this is my first attempt at Arduino programming. Maybe I should have started with the blink test.
See if that works.
OOPs, int tempCDS18B20; should be float tempCDS18B20;
I tried that and no difference.
I do not think it is reading the temp (DS18B20). I changed the 'if' statement to <= 0 and the first 'else' statement to >=1... this should make the second LED light up instead of first blinking ,but it does not, the first still blinks. Do I need to have a Celsius conversion formula in my sketch? (I assumed there is one in <DallasTemp.h>). I checked the other LED's by adding digitalWrite to void setup and they turn on during setup. I checked for continuity between sensor wires > breadboard> arduino and there is no problem. I did find I get a voltage reading [at sensor] between the signal wire and data wire.
Assign that return value to a float variable, then in your if-else-if chain use the same variable!
You first version assigned the result to a different variable from the one you tested,
the later one assigned it to an int which you then tested against over-large values.
If you do
#include <DallasTemperature.h>
Then be sure to actually look at that include file yourself to see what each function does and what
its arguments are and return type is!
And please indent your code properly, and please make it readable:
Hard to read:
else if(tempCDS18B20>=17.5&&tempCDS18B20<20)
Easy to read:
else if (temp >= 17.5 && temp < 20)
Lack of whitespace makes it hard to see silly errors, and make sense of the code, over complex
variable name is just visual noise - the variable is a temperature, whether it came from a DS18B20 or an LM35 or an XYZ3823823dcSDCds7383 is irrelevant to code that is comparing temperatures.
Break the code down into small functions with concise but meaningful names and it will become
much easier to read and maintain too. Any function over 20 lines is a clue you are not structuring
the code enough.
