temp sensor not reading
hi guys why would the temp sensor only read while the start button is pressed i cant get my head around it
#include <Wire.h>
#include <max6675.h>
LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE); // Set the LCD I2C address
#define Start 4 // start stop button
#define COOKER  13
int thermoDO = 8;
int thermoCS = 5;
int thermoCLK = 7;
MAX6675 thermocouple(thermoCLK, thermoCS, thermoDO);
uint8_t degree[8]  = {140, 146, 146, 140, 128, 128, 128, 128};
int hours = 0;
int minutes = 0;
int seconds = 0;
boolean timeState = false;
#define encoderPinA 2 // right
#define encoderPinB 3 // left
#define encoderButton 6 // switch
#define gnd2 12
#define vcc2 11
#define gnd3 10
int HMS = 1;
int encoderPos = 0; // a counter for the dial
unsigned int lastReportedPos = 1; // change management
static boolean rotating = false; // debounce management
boolean A_set = false;
boolean B_set = false;
  pinMode(COOKER, OUTPUT);
  digitalWrite(COOKER , HIGH);
  pinMode (vcc2 , OUTPUT);
  digitalWrite(vcc2, HIGH);
  pinMode(gnd3, OUTPUT);
  digitalWrite(gnd3, LOW);
  pinMode (gnd2 , OUTPUT);
  digitalWrite(gnd2 , LOW);
  pinMode(Start, INPUT_PULLUP);
  pinMode(encoderPinA, INPUT_PULLUP); //enabling pullups
  pinMode(encoderPinB, INPUT_PULLUP);
  pinMode(encoderButton, INPUT_PULLUP);
  attachInterrupt(0, doEncoderA, CHANGE); //pin 2
  attachInterrupt(1, doEncoderB, CHANGE); //pin 3
  Serial.begin(9600); // output
  lcd.begin(16, 2); // initialize the lcd for 16 chars 2 lines, turn on backlight
  lcd.clear();
  lcd.setCursor(0, 0);
  lcd.print ("COOKER");
  lcd.setCursor(4, 1);
  lcd.print("00:00:00");
  lcd.setCursor(15, 0);
  lcd.print("C");
  lcd.setCursor(7, 0);
  lcd.print( thermocouple.readCelsius(), 2);
  Serial.print(thermocouple.readCelsius());
  if (digitalRead(encoderButton) == LOW)
    HMS = HMS + 1;
    if (HMS == 4)
      HMS = 1;
  rotating = true; // reset the debouncer
  encoderPos = constrain(encoderPos, -1, 1);
  if (lastReportedPos != encoderPos) {
    if (HMS == 1) {
      hours = hours + encoderPos;
      hours = constrain(hours, 0, 48);
    else if (HMS == 2) {
      minutes = minutes + encoderPos;
      minutes = constrain(minutes, 0, 60);
    else if (HMS == 3) {
      seconds = seconds + encoderPos;
      seconds = constrain(seconds, 0, 60);
    // Serial.println(encoderPos); // for testing
    // Serial.print("hours ");
    // Serial.println(hours);
    // Serial.print("minutes ");
    // Serial.println(minutes);
    // Serial.print("seconds ");
    // Serial.println(seconds);
    // Serial.println(" ");
    if (hours <= 9)
      lcd.print("0");
    lcd.print(hours);
    lcd.print(":");
    if (minutes <= 9)
      lcd.print("0");
    lcd.print(minutes);
    lcd.print(":");
    if (seconds <= 9)
      lcd.print("0");
    lcd.print(seconds);
    encoderPos = 0;
    lastReportedPos = encoderPos;
  if (digitalRead(Start) == LOW) { //start count down timer
    timeState = true;
    //delay(1000);
    while (timeState == true) {
      if (minutes == 0 && hours >= 1) {
        minutes = 60;
        hours = hours - 1;
      if (seconds == 0 && minutes >= 1) {
        seconds = 60;
        minutes = minutes - 1;
      else if (minutes == 0 && hours == 0 && seconds == 0) { //count down alarm
          tone(11, 600, 250);
          delay(250);
          tone(11, 800, 250);
          delay(250);
      delay(992); // delay for keping time master setting!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
      seconds = seconds - 1;
      //Serial.print("hours "); // for testing
      //Serial.println(hours);
      //Serial.print("minutes ");
      //Serial.println(minutes);
      //Serial.print("seconds ");
      //Serial.println(" ");
      if (hours <= 9)
        lcd.print("0");
      lcd.print(hours);
      lcd.print(":");
      if (minutes <= 9)
        lcd.print("0");
      lcd.print(minutes);
      lcd.print(":");
      if (seconds <= 9)
        lcd.print("0");
      lcd.print(seconds);
        timeState = false;
// Interrupt on A changing state
void doEncoderA() {
  // debounce
  if ( rotating ) delay (1); // wait a little until the bouncing is done
  // Test transition, did things really change?
  if ( digitalRead(encoderPinA) != A_set ) { // debounce once more
    A_set = !A_set;
    // adjust counter + if A leads B
    if ( A_set && !B_set )
      encoderPos = 1;
    rotating = false; // no more debouncing until loop() hits again
// Interrupt on B changing state
void doEncoderB() {
  if ( digitalRead(encoderPinB) != B_set ) {
    B_set = !B_set;
    // adjust counter - 1 if B leads A
    if ( B_set && !A_set )
      encoderPos = -1;
    rotating = false;
