I have written the code for the DHT22 with Aduino ide but i the serial print to hold the max temperature this where I am lost.
I don't know how to write the code to print the max temperature and the current temperature.
I need to know the maximum temperature for the day or week before resetting it.
Welcome to the forum
You started a topic in the Uncategorised category of the forum when its description explicitly tells you not to
Your topic has been moved to a relevant category. Please be careful in future when deciding where to start new topics
Please post your sketch, using code tags when you do
Posting your code using code tags prevents parts of it being interpreted as HTML coding and makes it easier to copy for examination
In my experience the easiest way to tidy up the code and add the code tags is as follows
Start by tidying up your code by using Tools/Auto Format in the IDE to make it easier to read. Then use Edit/Copy for Forum and paste what was copied in a new reply. Code tags will have been added to the code to make it easy to read in the forum thus making it easier to provide help.
This is my code:
#include <DHT.h>
#include <DHT.h>
#define Type DHT22
int sensePin= 2;
DHT HT(sensePin, Type);
float humidity;
float tempC;
float tempF;
int setTime = 1000;
int dt=0;
int whitePin =8;
pinMode (sensePin, INPUT);
pinMode(whitePin, OUTPUT);
Serial.println(tempC);
HT.begin();
delay (setTime);
humidity=HT.readHumidity();
tempC=HT.readTemperature();
tempF=HT.readTemperature();
Serial.print("Humidity: ");
Serial.println(humidity);
Serial.print(" Temperature C ");
Serial.print(" C ");
Serial.println(tempF);
Serial.println(" F ");
if ( tempF > 34.0) {
digitalWrite (whitePin, HIGH);
if (tempC <34.0) {
digitalWrite (whitePin, LOW);
type or paste code here
