Temp sensor
I purchased this temp sensor.
I googled about how to use it and I saw some had mentioned to use a 4.7k resistor between GND and Signal wires. Is that a must?
I think YES.
But you can find it out by testing with/without the resistor.
Mightbe also depending on the distance between the sensor’s planned operational location and your Arduino.
A definite NO. The resistor goes between power and signal, and that is the must.
http://www.hacktronics.com/Tutorials/arduino-1-wire-tutorial.html
Thank you very much
