Hi.
Has any one used a TMP36GT9 Low Voltage Temperature Sensors with arduino is there any special i need to do to use this sensor.
thanks chilliman
Hi.
thanks chilliman
Shouldn't be a problem. Take an analog reading. Calculate millivolts (reading * 5000) / 1024). Divide by 10. Subtract 50. Result is degrees centigrade.
http://www.instructables.com/id/Temperature-Sensor-Tutorial/ should answer all your questions.
thanks very helpful
chilli man ![]()
chilliman:
One thing you might do is check the packaging options. If you can get the TMP36 the way you want it, fine, but I wouldn't look at anything other than the DS18B20 for that sort of range. It's digital, which goes down well in this digital world, and it comes like this
