I am trying to get the temperature from my DHT22 across Json so a webage can display the values. I am having an issue where the values are intermittent and show arduinoEthernetComCallback('{"DHT_Temp": -1766.20,"DHT_Hmuid": -999.00}') one second then
arduinoEthernetComCallback('{"DHT_Temp": 25.6,"DHT_Hmuid": 40.5}').
I cant figure out why it's not staying on the correct values only. I'm sure its a code issue, I'm still new and learning!
Thanks for any help
#include <SPI.h>
#include <Ethernet.h>
#include <dht.h>
dht DHT;
#define DHT22_PIN 7
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network:
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress ip(10,50,50,227);
char callback[27] = "arduinoEthernetComCallback";
// Initialize the Ethernet server library
// with the IP address and port you want to use
// (port 80 is default for HTTP):
EthernetServer server(80);
 // start the Ethernet connection and the server:
Ethernet.begin(mac, ip);
server.begin();
// listen for incoming clients
if (client) {
// an http request ends with a blank line
boolean currentLineIsBlank = true;
while (client.connected()) {
if (client.available()) {
char c = client.read();
// if you've gotten to the end of the line (received a newline
// character) and the line is blank, the http request has ended,
// so you can send a reply
if (c == '\n' && currentLineIsBlank) {
// send a standard http response header
DHT.read22(DHT22_PIN);
client.println("Content-Type: application/json");
client.println();
// output the value of each analog input pin as a json-p object
float temperatureDegF = Fahrenheit(DHT.temperature);
float humidity = DHT.humidity;
client.print(callback);
client.print("('{");
client.print("\"DHT_Temp");
client.print("\": ");
client.print(temperatureDegF);
client.print(",");
client.print("\"DHT_Hmuid");
client.print(humidity);
client.println("}')");
if (c == '\n') {
// you're starting a new line
else if (c != '\r') {
// you've gotten a character on the current line
currentLineIsBlank = false;
// give the web browser time to receive the data
delay(1);
// close the connection:
client.stop();
//Celsius to Fahrenheit conversion
double Fahrenheit(double celsius)
    return 1.8 * celsius + 32;
Seems that DHT.temperature is giving you an unexpected value.
What DHT library are you using? Have you tested basic reading of your sensor with this library to confirm it produces consistent data when you use it like this?
You aren't checking the returned status from dht.read(). You need to do that to know whether the read succeeded. In general, aim to call the DHT library in exactly the same way in your project sketch as the way you used it when you were testing the sensor - and that should be consistent with the DHT library examples.
Are you referring to this for checking the returned status?
switch (chk)
  case DHTLIB_OK:
    Serial.print("OK,\t");
    del -= 10;
  case DHTLIB_ERROR_CHECKSUM:
    Serial.print("Checksum error,\t");
  case DHTLIB_ERROR_TIMEOUT:
    Serial.print("Time out error,\t");
    del += 10;
  default:
    Serial.print("Unknown error,\t");
This is the whole file from the DHT22_Test
//Â Â FILE: dht22_test.ino
//Â AUTHOR: Rob Tillaart
// VERSION: 0.1.01
// PURPOSE: DHT library test sketch for DHT22 && Arduino
//Â Â URL:
// Released to the public domain
#include <dht.h>
dht DHT;
#define DHT22_PIN 5
  Serial.println("DHT TEST PROGRAM ");
  Serial.print("LIBRARY VERSION: ");
  Serial.println(DHT_LIB_VERSION);
  Serial.println("Type,\tstatus,\tHumidity (%),\tTemperature (C)\tTime (us)");
  // READ DATA
  Serial.print("DHT22, \t");
  uint32_t start = micros();
  int chk = DHT.read22(DHT22_PIN);
  uint32_t stop = micros();
  switch (chk)
  case DHTLIB_OK:
  default:
  // DISPLAY DATA
  Serial.print(DHT.humidity, 1);
  Serial.print(",\t");
  Serial.print(DHT.temperature, 1);
  Serial.print(stop - start);
  delay(2000);
// END OF FILE
dancinj:
That will print out a description of the status. If you want to do that, that's fine. The main thing is that you need to check what the return value from dht.read22() is - the value that is assigned to chk in the DHT22_Test sketch, but which you discard in your one.
 float temperatureDegF;
 float humidity;
Â
 uint32_t start = micros();Â
Â
 switch (chk)
  case DHTLIB_OK:
I'm not exactly sure what line of code is needed to check the return value from dht.read22()
