Temperature and Humidity Detector
This is my coding to detect temperature and humidity…I need to insert minimum and maximum temperature…Can anyone please help with that?
Thank you very much
// #include <Arduino.h>
#include <ESPert.h>
ESPert espert;
const char* mqtt_server = "mqtt.espert.io";
unsigned long loopTime = 0;
int currentSwitch = true;
String outTopic = "ESPert/" + String(espert.info.getChipId()) + "/Status";
String inTopic = "ESPert/" + String(espert.info.getChipId()) + "/Command";
int currentSwitch2 = true;
ESPert_Button button2;
const char* host = "maker.ifttt.com";
const int httpPort = 80;
String ifttt_key = "";
void callback(char* topic, byte* payload, unsigned int length) {
  String strPayload = String((char*)payload).substring(0, length);
  espert.println("Receive: " + strPayload);
  espert.oled.clear();
  espert.oled.println(espert.info.getId());
  espert.oled.println();
  espert.oled.printf("[%lu]\r\n\r\n", millis());
  espert.oled.println("PARSE OK.");
  if (espert.json.init(strPayload)) {
    if (espert.json.containsKey("LED")) {
      String value = espert.json.get("LED");
      if (value == "0") {
        espert.led.off();
        espert.println("LED: Off");
      } else if (value == "1") {
        espert.led.on();
        espert.println("LED: On");
      } else if (value == "2") {
        if (espert.led.isOn()) {
          espert.led.off();
          espert.println("LED(Toglle): off");
          espert.led.on();
          espert.println("LED(Toglle): On");
      String outString = "{\"LED\":\"" + String(espert.led.isOn() ? 1 : 0) + "\", ";
      outString += "\"name\":\"" + String(espert.info.getId()) + "\"}";
      espert.println("Send...: " + outString);
      espert.mqtt.publish(outTopic, outString);
    if (espert.json.containsKey("Buzzer")) {
      String value = espert.json.get("Buzzer");
      int l = value.toInt();
      for (int i = 0; i < l; i++) {
        delay(200);
        espert.buzzer.beep(60, 200);
    if (espert.json.containsKey("OLED")) {
      String value = espert.json.get("OLED");
      espert.oled.println(value);
    if (espert.json.containsKey("IFTTT")) {
      String value = espert.json.get("IFTTT");
      ifttt_key = value;
      espert.eeprom.write(150, ifttt_key);
      String outString = "{\"IFTTT\":\"" + ifttt_key + "\", ";
  else {
    espert.oled.println("PARSE FAILED.");
  espert.init();
  delay(100);
  espert.buzzer.init(15);
  espert.dht.init();
  espert.mqtt.init(mqtt_server, 1883, callback);
  ifttt_key = espert.eeprom.read(150, 80);
  button2.init(0);
  espert.oled.init();
  delay(2000);
  espert.println("Press USER button to switch Mode");
  int mode = espert.wifi.init();
  if (mode == ESPERT_WIFI_MODE_CONNECT) {
    espert.println(">>> WiFi mode: connected.");
    espert.oled.println("WiFi: connected.");
    espert.oled.print("IP..: ");
    espert.oled.println(espert.wifi.getLocalIP());
  } else if (mode == ESPERT_WIFI_MODE_DISCONNECT) {
    espert.println(">>> WiFi mode: disconnected.");
    espert.oled.println("WiFi: not connected.");
  loopTime = millis();
  espert.loop();
  if (espert.mqtt.connect()) {
    espert.println("MQTT: Connected");
    espert.println("MQTT: Out Topic " + outTopic);
    espert.mqtt.subscribe(inTopic);
    Serial.println("MQTT: Subscribed " + inTopic);
  bool buttonPressed = espert.button.isOn();
  if (buttonPressed != currentSwitch) {
    String outString = "{\"button\":\"" + String(buttonPressed ? 1 : 0) + "\", ";
    currentSwitch = buttonPressed;
  buttonPressed = button2.isOn();
  if (buttonPressed != currentSwitch2) {
    espert.println("SW");
    if (buttonPressed) {
      String path = "/trigger/button/with/key/" + ifttt_key;
      espert.println(">>" + espert.wifi.postHTTP(host, path.c_str()) + "<<");
    currentSwitch2 = buttonPressed;
  if (millis() - loopTime >= 5000) {
    float t = espert.dht.getTemperature();
    float h = espert.dht.getHumidity();
    float tempMin = 30;
    float tempMax = 32;
    if (!isnan(t) && !isnan(h)) {
      String outString = "{\"temperature\":\"" + String(t) + "\", ";
      outString += "\"humidity\":\"" + String(h) + "\", ";
      espert.println(outString);
      // espert.oled.clear();
      // espert.oled.println(String("....") + millis());
  delay(2000);
avinashrao0409:
....I need to insert minimum and maximum temperature...
You can insert everywhere in your code !
Honestly, it's really hard to give comments for your question because not clear what you want to do with min, max temperature. You should be more details your purpose or trouble for easier to understand and support.
