Temperature control program
Hello
I have a heating program of a resistance that works with a potentiometer to set the temperature, and with a second I measure the temperature (two programs Flowcode V6 that I have to compile on an Arduino card). Except that I would need a program to regulate the temperature according to the temperature but I do not manage it, so if someone can help me.
Enclosed you have my two programs:
Nothing attached.
Also post your best attempt at merging the programs.
This Simple Merge Demo may help.
Before trying to merge the programs go through each of them carefully to make sure they are not trying to use the same resource - for example an I/O pin. If you find conflicts change something in one of the separate programs and make sure it still works with the change.
...R
Thanks, I'll try that then
The problem is that my programs sound on the software Flowcode V6 and that you presented me an Arduino code
misterA:
The problem is ...you presented me an Arduino code
That's not unreasonable is it, after all this is an Arduino forum.
You know a forum for Flowcode?
misterA:
I never heard of Flowcode before you mentioned it. When I read your Original Post I had assumed it is an Arduino library.
...R
