Temperature Control Using Arduino UNO
Where did you get the code you posted ?
Try this :
 // SparkFun Serial LCD example 1
// Clear the display and say "Hello World!"
// This sketch is for Arduino versions 1.0 and later
// If you're using an Arduino version older than 1.0, use
// the other example code available on the tutorial page.
// Use the softwareserial library to create a new "soft" serial port
// for the display. This prevents display corruption when uploading code.
#include <SoftwareSerial.h>
// Attach the serial display's RX line to digital pin 2
SoftwareSerial mySerial(3,2); // pin 2 = TX, pin 3 = RX (unused)
  mySerial.begin(9600); // set up serial port for 9600 baud
  delay(500); // wait for display to boot up
  mySerial.write(254); // move cursor to beginning of first line
  mySerial.write(128);
  mySerial.write("                "); // clear display
  mySerial.write("Hello, world!");
  while(1); // wait forever
