temperature controlled relay with LCD Printout
hi i am a beginner to arduino, i have built a circuit using:
1 x uno 3 arduino
1 x lcd screen
1 x potentiometer
1 x LM35
1 x Relay module Single channel
1 x RTC Module
my goal was to turn on and off my new vivarium lights one uv light on at 8am and off at 8pm and another light the basking light to be turned on at 8am with off pulses throughout the day to maintain a temperature within the viv. The basking light will also end programming and turn off at 8pm.
At present i have used one relay as mentioned this will control the basking light for now and i will add a second or dual relay later for the UV control
my problems are when i connect the relay to digital pin 9 for UV control it works fine as this is just using the time in the if statement but when i connect the relay to digital pin 1 the if statement is test the time and the temperature and it pulses and crashes the program
i have tried all different types of code from the internet and ardunio ide examples but can't seem to figure it out
i am wondering is my code wrong or do i need a pullup resistor on relay circuit if resistor needed where does it need to go
i have added a copy of my code in attachments and a paste of it here for someone to maybe see if i am going wrong
thanks
stu
#include <LiquidCrystal.h> //Library LCD
#include <LM35.h> //LM35 Temp sensor library
#include <Wire.h>
#include <DS1307.h>
LiquidCrystal lcd(2,3,4,5,6,7); //configuration pin Arduino to LCD
LM35 temp(A0);
DS1307 clock;//define a object of DS1307 class
void setup(){
clock.begin();
clock.fillByYMD(2018,12,31);//Jan 19,2013
clock.fillByHMS(12,10,30);//15:28 30"
clock.fillDayOfWeek(MON);//Saturday
clock.setTime();//write time to the RTC chip
lcd.begin(16,2); //Initialize the LCD size used is the type of 16x2
lcd.setCursor(0,1); //Set the column and row
lcd.print("Temp:"); //Displays the value of the temperature
pinMode(1, OUTPUT);
pinMode(9, OUTPUT);
void loop (){
clock.getTime();
Serial.print(clock.hour, DEC);
Serial.print(":");
Serial.print(clock.minute, DEC);
Serial.print(":");
Serial.print(clock.second, DEC);
Serial.print(" ");
Serial.print(clock.month, DEC);
Serial.print("/");
Serial.print(clock.dayOfMonth, DEC);
Serial.print("/");
Serial.print(clock.year+2000, DEC);
Serial.print(" ");
switch (clock.dayOfWeek)// Friendly printout the weekday
case MON:
Serial.print("MON");
case TUE:
Serial.print("TUE");
case WED:
Serial.print("WED");
case THU:
Serial.print("THU");
case FRI:
Serial.print("FRI");
case SAT:
Serial.print("SAT");
case SUN:
Serial.print("SUN");
Serial.println(" ");
Serial.println(temp.getTemp()); //Temp in celcius to pc
lcd.setCursor(0,0);
lcd.print("Time: ");
lcd.print(clock.hour, DEC);
lcd.print(":");
lcd.print(clock.minute, DEC);
float temperature = temp.getTemp(); //store variable of temperature
lcd.setCursor(5, 1); //set column and row to start text
lcd.print(temperature); // output temp in celcius to lcd
lcd.print(" Celcius"); //print word celcius after temp numbers
delay(500); //Refresh readings from sensors
if (clock.hour >= 8)
digitalWrite(9,HIGH); //relay for uv tube
if (clock.hour >= 20)
digitalWrite(9,LOW); //relay for uv tube
if ( (clock.hour >= 8) && (temperature <= 28) ) //check time and temp
digitalWrite(1,HIGH); //relay for basking light
digitalWrite(1,LOW);
digitalWrite(1,LOW); //relay for basking light
thermometer_new_with_library_lm35_and_time.ino (2.39 KB)
sorry i think i have posted this in wrong section can you please move to correct section
haha < = 8 ) turned into smileys with sun shades
stuy1982:
That's the sort of thing that happens when you don't use code tags.
stuy1982:
Pins 0 and 1 on the Uno are internally connected to the USB-Serial interface. You can't use them as general purpose pins if you're using Serial in your sketch.
Try a different pin for the basking light relay.
Also
  1. Learn about the forum's code tags - it stops those little 8) smilies appearing in your code.
  2. You say you're using relay modules - you need to check if these have built-in freewheel diodes (most of them do).
GypsumFantastic:
Also
thanks for your response will try and look into everything mentioned
thanks again
stu
