Temperature Controlled RGB LED
So i want to make a project where the temperature reading dictates the colour of the RGB LED (ie. red when hot, blue when cold).
I currently have an RGB LED and an LM35 temperature sensor and know how to use them separately, but do not know how i can convert the temperature readings into 0-255 values.
Any help?
Thanks in advance.
matt559:
Math? Or you could try the map function. You'll have to think a little bit about how the temperatures should map to colors.
Forget the code for a minute. Work it out on paper. Once you figure out the math, making it into code is the easy part.
I was more looking for the actual code terms that could accomplish the conversion, and the 'map' function seems to achieve this so, thank you.
matt559:
You can't create the code until you have the math. Trying to do it the other way round is a recipe for frustration.
