temperature controlling system
I got a project to read temperature from PT-100 type sensors, the range is from -60 to 220 celsius, i have at least 4 sensors to read simultaneously and display them like excel sheet with date and record.
Can i make it with any arduino or genuino technology?
I need it for refrigeration system and motors and generators temperature monitoryzing in fishing ships.
Thanks
Why do you need PT100 sensors? They are difficult to use properly with Arduino.
For refrigeration temperature measurement, NTC (negative temperature coefficient) thermistor temperature sensor housed in ABS plastic tube is more more frequently used.
More information can be found in AMWEI Thermistor Sensor - Professional Manufacturer of PTC NTC Thermistors Heater Temperature Sensor
For motors temperature sensing protection, silicon PTC (Positive Temperature Coefficient) Thermistor temperature sensor, and PTC Thermistors Limit Temperature Sensor for Motor protection Single Sensors & Triple Sensors as well as PTC Thermistor Current Protector is more frequently used.
