Temperature Data using DS18B20 sensor
Hi guys. I am trying to adjust an arduino code that reads temperature data from a DS18B20 sensor and a code that can store things to a phpMyadmin database and i am a little confused. I hope i ask in the right part of the forum
Arduino Code that measures Temperature
#include <SPI.h>
#include <Ethernet.h>           //library for ethernet functions
#include <HTTPClient.h>             //library for client functions
[u]#include <DallasTemperature.h>[/u]  //library for temperature sensors
[u]#include <OneWire.h>[/u]          //library for the onewire bus
[u]#define ONE_WIRE_BUS     2[/u]    //the onewire bus is connected to pin 2 on arduino
[u]#define TEMPERATURE_PRECISION  10[/u] //resolution of the sensors is set to 10bit
// Ethernet settings
uint8_t hwaddr[6] = {
  xxxx, xxxx, xxxx, xxxx, xxxx, xxxx};
uint8_t ipaddr[4] = {
  xxx, xxx, x, xx };
uint8_t gwaddr[4] = {
  xxx, xxx, x, xx};
uint8_t subnet[4] = {
  xxx, xxx, x, xx};
uint8_t serverip[4] = {
  xxx, xxx, x, xx};
uint8_t serverport = 80;
EthernetClient client;
[u]OneWire oneWire(ONE_WIRE_BUS);      [/u]
[u]DallasTemperature sensors(&oneWire);   [/u]
int numSensors;
bool connected = false;
int i = 0;
void setup(void)
  Serial.println("I2C-to-Ethernet Bridge.");
  Serial.println("Initializing Ethernet.");
  Ethernet. begin(hwaddr, ipaddr);
  [u]sensors.begin(); [/u]
  Serial.println("Enumerating and scanning for I2C sensors.");
  [u]numSensors = sensors.getDeviceCount(); [/u]
  // "sensors.getDeviceCount" is a function in the library
  if(numSensors > 0)
    Serial.print("Enumerated ");
    Serial.print(numSensors);
    Serial.println( " sensors.");
    Serial.println("No sensors enumerated.");
void loop(void)
  if(!connected)   {
    //Serial.println("Not connected");
    if (client.connect(serverip,80)){
      connected = true;
      [u]sensors.requestTemperatures(); [/u]
      [u]float temp1 = sensors.getTempCByIndex(0); [/u]
      Serial.print("Temp is ");
      Serial.println(temp1);
      Serial.println("Sending to Server: ");
      client.print("GET /test_database.php?t");     // the database based on your post about php before
    [u] client.println(temp1);[/u]
      Serial.print(temp1);
      client.println(" HTTP/1.0");
      Serial.println(" HTTP/1.0");
      //client.println("Host: 192.168.x.x");
      //Serial.println("Host: 192.168.x.x");
      client.println();
      delay(20000);
    else{
      Serial.println("Cannot connect to Server");
  else {
    while (client.connected() && client.available()) {
      char c = client.read();
      Serial.print(c);
    client.stop();
    connected = false;
Arduino Code that sends data to Database
#include <SPI.h>
byte mac[] = {  xxxx,xxxx,xxxx,xxxx };
IPAddress ip(x,x,x,x);
IPAddress gateway(x,x,x,x);
IPAddress subnet(255, 255, 255, 0);
IPAddress server(1,2,3,4); // Change to your server ip
int totalCount = 0;
int loopCount = 0;
  pinMode(4,OUTPUT);
  digitalWrite(4,HIGH);
  Ethernet.begin(mac, ip, gateway, gateway, subnet);
  delay(2000);
  Serial.println("Ready");
char pageAdd[32];
  if(loopCount < 30)
    loopCount = 0;
    sprintf(pageAdd,"/test_database.php?temp1=%d",totalCount);
    if(!getPage(server,pageAdd)) Serial.print("Fail ");
    else Serial.print("Pass ");
    totalCount++;
    Serial.println(totalCount,DEC);
  loopCount++;
byte getPage(IPAddress ipBuf,char *page)
  int inChar;
  char outBuf[128];
  Serial.print("connecting...");
  if(client.connect(ipBuf,80))
    Serial.println("connected");
    sprintf(outBuf,"GET %s HTTP/1.0\r\n\r\n",page);
    client.write(outBuf);
    Serial.println("failed");
    return 0;
  int connectLoop = 0;
  while(client.connected())
    while(client.available())
      inChar = client.read();
      Serial.write(inChar);
      connectLoop = 0;
    delay(10);
    connectLoop++;
    if(connectLoop > 1000)
      Serial.println("Timeout");
      client.stop();
  Serial.println("disconnecting.");
  client.stop();
  return 1;
My point is to combine somehow these 2 codes in order to send my data to a database. Thank you very much
