I saw this project on the internet and I am trying to apply it but when I try to verify the code its give me an error: exit status 1
Error compiling for board Arduino Nano
so I try to download some files on the library but that doesn't work there my code and the schematic picture can anyone tell me the problem
"exit status 1" is just a generic error that only tells us something went wrong. There are an infinite number of possible causes of this error. You need to scroll the black console window at the bottom of the Arduino IDE up and look at the detailed error messages, which will tell you what the problem is.
When you encounter an error you'll see a button on the right side of the orange bar "Copy error messages". Click that button. Paste the error in a message here USING CODE TAGS (</> button on the forum toolbar).
Arduino: 1.8.8 (Windows Store 1.8.19.0) (Windows 10), Board: "Arduino Nano, ATmega328P"
In file included from C:\Users\natfa\Documents\Arduino\libraries\DHT_sensor_library\DHT_U.cpp:22:0:
C:\Users\natfa\Documents\Arduino\libraries\DHT_sensor_library\DHT_U.h:25:29: fatal error: Adafruit_Sensor.h: No such file or directory
compilation terminated.
exit status 1
Error compiling for board Arduino Nano.
option enabled in File -> Preferences.
When you see a "No such file or directory" error it almost always means you need to install the library that contains the missing file.
Often the code you're compiling will come with documentation (either a comment or separate document) that tells you where to get the library dependencies.
In other cases the author of the code will not have been so kind and you'll need to go on a hunt for the missing library.
A good place to start is the Arduino IDE's Library Manager:
Sketch > Include Library > Manage Libraries...
In the "Filter your search..." box, type some keywords you have gleaned from the missing file name.
Scroll through the results for the right library. Click on it.
Click "Install".
Wait for installation to finish.
Click "Close".
Try compiling your code again.
If you have no luck in Library Manager then load up your favorite search engine and do a search for the missing filename. You will often get multiple results. If you have a lot of results you might add "arduino" as an additional search keyword. I will usually prefer results on github.com since that is where most Arduino libraries are hosted and downloading from there is fast and easy. In some cases there will be multiple libraries that contain the given filename and you'll need to do some evaluation to determine which seems the most appropriate, then try it out. After downloading the library you found you'll need to install it. This requires a different process than the Library Manager installation. You will find instructions here:
