Hi Everybody,
I am looking for help writing a code which will enable me to trigger a relay for a certain amount of time (20 seconds) every time a Humidity and Temperature Sensor reads an incremental change, of +/- 1 degree for example.
I have searched for a code similar to this but have been unable to find one that works for me. So, any and all links are welcome.
Here is my code which I partly amended from another code I found.
int dataPin = 3;
int clockPin = 5;
int currentTemp = 0;
int currentHumidty = 0;
int previousTemp = 0;
int previousHumidity = 0;
int delta = 0;
int deltaValue = 0;
// will change
int Relay = 3
// change
Serial.begin(38400); // Open serial connection to report values to host
Serial.println("Starting up");
currentTemp = analogRead(dataPin); //read the sensor
currentTemp = map(currentTemp, 0, 1023, 0, 255); // map the value
currentTemp = constrain(currentTemp, 0, 255); // not sure this is useful
delta = abs(previousTemp - currentTemp); // calculate the absolute value of the difference btw privous and current light value
if (delta >= deltaValue) { // if the difference is higher than a threshold
Serial.print("currentTemp: ");
Serial.println(currentTemp);
digitalWrite(Relay, HIGH);
else {
digitalWrite(Relay, LOW);
currentTemp = previousTemp;
delay(2000);
Thank you anyone who can help with this.
