Hi. My ESP32 has been powered on for around 20 minutes, and it's at 43°C, is this normal?
I am using WiFi connectivity on it. The chip is an ESP32-WROOM-32.
Could be. I think ESP boards draw about 80mA typically. With 5V power supply that is 0.4W heat dissipation
I'm not sure how much is supplied, but it is a USB-C.
Do you have a temperature issue with the ESP32? Maybe yes, maybe no it’s hard to say without more information. Posting an annotated schematic that shows everything connected to the ESP32 would help us assist you better. The devices and components connected to the ESP32 can significantly impact its operating temperature.
Nothing is connected. Also, I found out that if I supply 3.3V, the temperature significantly drops.
Is that with a thermistor thermally coupled to the WROOM module?
I'm not sure.
That might be because it is rated for a voltage lower than 5V. The fact that it’s still working makes you quite lucky, but I wouldn’t trust it for anything important. You’ve likely caused some damage to it. I recommend replacing it, and if you encounter issues with that unit, test your design on a fresh device that has never been exposed to the wrong voltage.
Nothing seems to be damaged. But also, how do I shift the USB to output a lower voltage?
How are you measuring this temperature?
You cannot.
I'll just use my Arduino to supply 3.3V.
How are you measuring the temperature?
This topic discusses the temperature you can expect using the built-in die temperature sensor.
https://forum.arduino.cc/t/esp32-s2-built-in-temperature-sensor/1237935
Mine run warm, too.
Who would design something with a USB interface that isn't 5V tolerant when plugged into USB?
It' s not clear what it is that gets hot.(and how the temperature is measured)
I suspect it's the regulator that's warming up, which 5V to 3.3V regulator is used on that board?
Without knowing all the details, I would say yes. At normal 20'C room temp Esp32 feels slightly warm when you touch, around 40'C. Do you have some evidence that it might overheat? If you power it at 5V, voltage regulator is probably the hottest component.
The ESP32 chip gets hot, I measured the ESP32 externally.
