Hi I am new on this forum, and also when it comes to electronics and microprocessors.
I'm on to a project, trying to build a temperature regulation system in my sailboat, where I will use an arduino (pro mini), 1-wire temperature sensors (DS18B20), and some motor driver (L298).
The Arduino will control (PID, PWM) six 12v DC motors (fans) that will blow out heated air, from a heat exchanger, when needed.
Digging in this forum have given me a clue about how to use the the L298, but maybe some one can help me out before i start to fry components.
Is it ok to use two by pass diodes (they can only handle 1A each), ore is one enough?
Ok to connect IN1 and IN2 directly to 5V and GND?
-If I want to limit the current (short circuit protection) and put a resistor between GND and "1", how can I hock this up to a I/O pin on the arduino when its connected to the 12v, and not to the 5v. Transistor?
True... and less expensive than a relay, but not by much. If you want to "skip" one learning chore for the moment, a relay is an easier-to-understand (and do right) answer. Just be sure to include The Diode.
Richard, even whit my limited knowledge I must say that it make sense.... I will search on this forum to find out how to do it with a transistor in stead.
Unfortunately the relay will not do the job since I want to control the speed of the motors (PWM). How ever I have plans to drive a 12v circulation pump for the water system, and will use this setup.
Done some research about controlling the DC motors, and have learned a bite about Optokoplers, Darlington transistors...
Since I already have ordered the L298, and figured out how they works, maybe I will leave the transistor controlling to another project. And go for the L298, even though I not using their full functionality.
Isn't it so that the arduino maximum can deliver 30mA on one pin?
And if I need 4A (guessing) start up current, I would need a gain of at least 4/0.03= 130?
Doesn't I need a darlington to fix this?
