temperature sensing code
Hi
I’ve written some code for a temperature sensing textile but it’s not working properly. It compiles as being correct, but when uploaded, the serial monitor and the led display do not correspond. Whatever the temperature I only get the last led display. Any advice greatly appreciated. Here’s the code:
float temp,tempAvg, tempA;
long previousMillis = 0;
long interval = 2000;
int count = 0;
int ledPin1 = 5;       //put the LED light on pin 5
int ledPin2 = 9;      //put the LED light on pin 9
int ledPin3 = 11;      //put the LED light on pin 11
/*int positivePin = A5;   //setting A5 to be a positive pin.*/
int brightness1 = 15;    // how bright the LED is
int fadeAmount1 = 5;    // how many points to fade the LED by
int brightness2 = 25;    // how bright the LED is
int fadeAmount2 = 5;    // how many points to fade the LED by
int brightness3 = 35;    // how bright the LED is
int fadeAmount3 = 10;    // how many points to fade the LED by
Serial.begin(57600);
pinMode(ledPin1, OUTPUT); //Setting LED 1 (lightPin1) to be an output. Ditto for each of the other LEDs
pinMode(ledPin2, OUTPUT);
pinMode(ledPin3, OUTPUT);
void loop () {
  if(currentMillis - previousMillis > interval) {
temp = analogRead(A5)*5/1024.0;
temp = temp - 0.5;
temp = temp / 0.01;
Serial.print("temp: ");
Serial.println(temp);
//tempAvg = tempAvg + temp;
//count++;
//if (count > 7) {
//  tempA = tempA - temp;
//  count = 0;
//tempA = tempAvg/8.;
//  Serial.print("tempA: ");
//  Serial.println(tempA);
if ((temp >= 18.0) && (temp < 23.0)) {
// set the brightness of all three LEDS:
analogWrite(ledPin1, max(brightness1, 0));
analogWrite(ledPin2, max(brightness2, 0));
analogWrite(ledPin3, max(brightness3, 0));
// change the brightness for next time through the loop:
brightness1 = brightness1 + fadeAmount1;
brightness2 = brightness2 + fadeAmount2;
brightness3 = brightness3 + fadeAmount3;
} else if ((temp >= 23.0) && (temp < 28.0)) {
  // do something else
  void loop();
  digitalWrite(ledPin1, HIGH);   // sets the LED on
  delay(1000);                  // waits for a second
  digitalWrite(ledPin1, LOW);    // sets the LED off
  digitalWrite(ledPin2, HIGH);   // sets the LED on
  digitalWrite(ledPin2, LOW);    // sets the LED off
  digitalWrite(ledPin3, HIGH);   // sets the LED on
  digitalWrite(ledPin3, LOW);    // sets the LED off
else if ((temp >= 28.0) && (temp < 33.0)); {
  void loop();
 delay (200);                     //delay 20 miliseconds
 digitalWrite(ledPin1, LOW);    //led off
 delay (200);
 delay (200);
  void loop();
Why do you keep including a function prototype in your code?
The code you posted doesn't compile.
Should there be only one void loop? The code does compile when I use it but it's not doing what I want it to do. Maybe it copied incorrectly.
