temperature sensor code notworking
Hello guys,
during quarantine me and my landlord decided to automate his DIY campervan, meaning I'd deal with all the arduino end of things...
we need 4 light switches and a global switch, water temperature control and level meter, and batteries voltages. I'm using the "Bluetooth Electronics" app so I dont have to develop my own, and I have tested all individual component of the final build by its self and in little groups and everything works... the problem arises when I have all together (or all I have done so far together), the temperature meter stops working; it outputs allways the same two values "-271.3" and some times "-91". It is the exact same code that works stand alone but for some reason, when i add the switches it just breaks. Here is the code
#include "HX711.h"
HX711 scale;
#define main         2
#define ledTwo       3
#define ledThree     4
#define ledFour      5
#define ledFive      6
#define global       7
#define tempCon      8
#define sck          A0
#define lvlOut       A1
#define tempSens     A2
#define leisureBatt  A3
#define carBatt      A4
int update_interval=100; // time interval in ms for updating panel indicators
unsigned long last_time=0; // time of last update
char data_in; // data received from serial link
int slider_value; // Received Slider Values
String text; // String for text elements
int red,green,blue,greenTwo; // RGB color
int bubbles; // Bubble Gauge Value
int mapped, T;
const unsigned long eventTime_1_press = 5000;
const unsigned long eventTime_2_temp = 5000;
unsigned long previousTime_1;
unsigned long previousTime_2;
int Vo;
float R1 = 9800;
float logR2, R2;
float A = 1.009249522e-03, B = 2.378405444e-04, C = 2.019202697e-07;
  pinMode(main,        OUTPUT);
  pinMode(ledTwo,      OUTPUT);
  pinMode(ledThree,    OUTPUT);
  pinMode(ledFour,     OUTPUT);
  pinMode(ledFive,     OUTPUT);
  pinMode(global,      OUTPUT);
  pinMode(tempCon,     OUTPUT);
  pinMode(tempSens,    OUTPUT);
  pinMode(carBatt,     OUTPUT);
  pinMode(leisureBatt, OUTPUT);
  /*pannel builder code*/
  Serial.println("*.kwl");
  Serial.println("clear_panel()");
  Serial.println("set_grid_size(16,9)");
  Serial.println("add_text(1,2,large,R,LED 2,245,240,245,)");
  Serial.println("add_text(1,0,large,R,Main,245,240,245,)");
  Serial.println("add_text(1,6,large,R,LED 4,245,240,245,)");
  Serial.println("add_text(1,4,large,R,LED 3,245,240,245,)");
  Serial.println("add_text(6,7,large,L,Car batt.,245,240,245,)");
  Serial.println("add_text(11,7,large,L,Leisure batt.,245,240,245,)");
  Serial.println("add_text_box(10,0,2,L,Text,245,240,245,S)");
  Serial.println("add_text_box(13,0,2,L,Text,245,240,245,P)");
  Serial.println("add_text_box(7,0,2,L,Text,245,240,245,T)");
  Serial.println("add_text_box(7,8,3,L,Text,245,240,245,V)");
  Serial.println("add_text_box(12,8,3,L,Text,245,240,245,U)");
  Serial.println("add_text(14,5,large,L,Press.,245,240,245,)");
  Serial.println("add_text(8,5,large,L,Temp,245,240,245,)");
  Serial.println("add_text(1,8,large,R,Global ,245,240,245,)");
  Serial.println("add_switch(2,0,1,M,m,0,0)");
  Serial.println("add_switch(2,2,1,L,l,0,0)");
  Serial.println("add_switch(2,4,1,N,n,0,0)");
  Serial.println("add_switch(2,6,1,O,o,0,0)");
  Serial.println("add_switch(2,8,1,G,g,0,0)");
  Serial.println("add_switch(10,5,1,Y,y,0,0)");
  Serial.println("add_slider(10,1,3,50,100,100,R,r,0)");
  Serial.println("add_led(4,0,1,A,0,0,0)");
  Serial.println("add_led(4,2,1,B,0,0,0)");
  Serial.println("add_led(4,4,1,C,0,0,0)");
  Serial.println("add_led(4,6,1,D,0,0,0)");
  Serial.println("add_led(11,3,1,J,0,0,0)");
  Serial.println("add_led(4,8,1,W,255,0,0)");
  Serial.println("add_gauge(7,1,3,0,100,0,F,,,10,5)");
  Serial.println("add_gauge(13,1,3,0,100,0,H,,,10,5)");
  Serial.println("set_panel_notes(,,,)");
  Serial.println("run()");
  Serial.println("*");
  /*Pressure sensor calibration*/
  scale.begin(A1, A0);
  Serial.println(scale.read());
  Serial.println(scale.read_average(20));
  Serial.println(scale.get_value(5));
  Serial.println(scale.get_units(5), 1);
  scale.set_scale(2280.f);
  scale.tare();
  unsigned long currentTime = millis();
    /*pressure sensor code*/
    if(currentTime - previousTime_1 >= eventTime_1_press ){
        float percent = scale.get_units(10);
        mapped = map(percent, 89, 421, 0, 100);
        scale.power_down();
        scale.power_up();
        text=mapped;
        Serial.print("*H"+text+"*");
        Serial.print("\t");
        bubbles=mapped;
        Serial.println("*P"+String(bubbles)+"*");
        previousTime_1 = currentTime;
    /*temperature sensor code*/
    if(currentTime - previousTime_2 >= eventTime_2_temp ){
        Vo = analogRead(tempSens);
        R2 = R1 * (1023.0 / (float)Vo - 1.0);
        logR2 = log(R2);
        T = (1.0 / (A + B*logR2 + C*logR2*logR2*logR2));
        T = T - 273.15;
        text=T;
        Serial.print("*T"+text+"*");
        bubbles=T;
        Serial.print("\t");
        Serial.println("*F"+String(bubbles)+"*");
        previousTime_2 = currentTime;
  /*switches code*/
  if (Serial.available()){
    data_in=Serial.read();  //Get next character
    if(data_in=='G'){
       digitalWrite(global, HIGH);
       red=255; green=0; blue=0;
       Serial.println("*WR"+String(red)+"G"+String(green)+"B"+String(blue)+"*");
    if(data_in=='g'){
       digitalWrite(global, LOW);
       red=0; green=0; blue=0;
    if(data_in==('M')){
       digitalWrite(main, HIGH);
       red=255; green=255; blue=255;
       Serial.println("*AR"+String(red)+"G"+String(green)+"B"+String(blue)+"*");
    if(data_in=='m'){
       digitalWrite(main, LOW);
    if(data_in==('L')){
       digitalWrite(ledTwo, HIGH);
       Serial.println("*BR"+String(red)+"G"+String(green)+"B"+String(blue)+"*");
    if(data_in=='l'){
       digitalWrite(ledTwo, LOW);
    if(data_in==('N')){
       digitalWrite(ledThree, HIGH);
       Serial.println("*CR"+String(red)+"G"+String(green)+"B"+String(blue)+"*");
    if(data_in=='n'){
       digitalWrite(ledThree, LOW);
    if(data_in==('O')){
       digitalWrite(ledFour, HIGH);
       Serial.println("*DR"+String(red)+"G"+String(green)+"B"+String(blue)+"*");
    if(data_in=='o'){
       digitalWrite(ledFour, LOW);
    if(data_in==('Y')){
       Serial.println("*JR"+String(red)+"G"+String(green)+"B"+String(blue)+"*");
    if(data_in=='y'){
    if(data_in=='R'){
      slider_value=Serial.parseInt();
      text=slider_value;
      Serial.println("*S"+text+" 'C"+"*");
    if(data_in=='Y' && T<slider_value){
      pinMode(tempCon, HIGH);
    if(data_in=='y'){
      pinMode(tempCon, LOW);
  /////////////  Send Data to Android device
  if ((currentTime-last_time)>update_interval){
    last_time=currentTime;
    text="abc";
    Serial.print("*V"+text+"*");
    text="abc";
    Serial.print("*U"+text+"*");
What am i doing wrong?
(deleted)
