how to use temperature sensor devantech tsa01 for arduino?
how much convertion code?
Help me Please
Hi, and welcome to the forum.
Output 10.0 mV/°C (typical)
Output Voltage at 0°C 500mV
Specs are the same as the TMP36.
Use a sketch written for the TMP36.
Plenty of them online and on this site.
Enter "TMP36" in the search box on top of this page.
Here's one I wrote.
Leo..
// TMP36 temp sensor output connected to analogue input A0
// power pin connected to 3.3volt
unsigned int total; // A/D readings
float tempC; // Celcius
float tempF; // Fahrenheit
 analogReference(INTERNAL); // use the internal ~1.1volt reference | change to (INTERNAL1V1) for a Mega
 // read the sensor
 for (int x = 0; x < 64; x++) { // 64(max) analogue readings for averaging
  total = total + analogRead(A0); // add each value
 // temp conversion
 tempC = total * 0.001632 - 50.0; // Calibrate by slightly changing 0.0016xx
 tempF = tempC * 1.8 + 32; // Celcius to Fahrenheit
 Serial.print("The temperature is ");
 Serial.print(tempC, 1); // one decimal place
 Serial.print(" Celcius ");
 Serial.print(tempF, 1); // one decimal place
 Serial.println(" Fahrenheit");
 total = 0; // reset total
 delay(1000); // slows readings
Thanks Wawa
My students, I have learned arduino.
Devantech wear tsa01 but still confused how to use.
if there is any more trouble, I am asking for help from all of you.
thanks for all
