hi everyone
i use two temperature sensor and i try to if the room0's temperature > 30. The led will light.
But it didn't.
this is my code
#include <OneWire.h>
#include <DallasTemperature.h>
int ledPin = 13;
// Data wire is plugged into pin 3 on the Arduino
#define ONE_WIRE_BUS 3
// Setup a oneWire instance to communicate with any OneWire devices
OneWire oneWire(ONE_WIRE_BUS);
// Pass our oneWire reference to Dallas Temperature.
DallasTemperature sensors(&oneWire);
DeviceAddress room0 = { 0x28, 0xA0, 0x02, 0xB4, 0x04, 0x00, 0x00, 0xC0 };
DeviceAddress room1 = { 0x28, 0x08, 0x43, 0xB4, 0x04, 0x00, 0x00, 0x19 };
int i;
void setup(void)
// start serial port
// Start up the library
sensors.begin();
// set the resolution to 10 bit
sensors.setResolution(room0, 10);
sensors.setResolution(room1, 10);
void printTemperature(DeviceAddress deviceAddress)
float tempC = sensors.getTempC(deviceAddress);
if (tempC == -127.00) {
Serial.print("Error getting temperature");
Serial.print("C: ");
Serial.print(tempC);
Serial.print(" F: ");
Serial.print(DallasTemperature::toFahrenheit(tempC));
void loop(void)
delay(2000);
Serial.print("Getting temperatures...\n\r");
sensors.requestTemperatures();
for(i = 0; i<2; i++){
Serial.print("room");
Serial.print(i);
Serial.print(": ");
Serial.println(sensors.getTempCByIndex(i));
float room0 = sensors.getTempCByIndex(0);
if(room0>30.00)
digitalWrite(ledPin,HIGH);
return;
how can i modify
please help me
