Temperature sensor values on seven segment displays.
Hi everyone.
I'd appreciate some help on what I am trying to achieve here. So:
In my circuit I have a DS18B20 temperature sensor, and 3 seven segment displays.
What I am trying to do is to pass the values of the sensor, into the displays.
As a complete beginner coder, here is what I am thinking to do:
The temperature value is a float, in the form of 29.55
I will multiply this float with 100, in order to give it the form of an integer, like 2955
Then, I need somehow to do the following:
    • Read the first digit of the 2955 value.
    • If the first number of the int is 1, then do function 1 (a function that lights the segments for the 1 digit).
    • If first number is 2, then do function 2 etc...
I will repeat the above process for the next 2 digits of the int 2955, and hopefully I will end with my 3 seven segment displays to show the temperature values.
SO, my question is:
is there a way that I can read the numbers of the int value one by one? Or I will first need to convert the int into some other data type first?
And, above all, is my thinking valid? Or completely out of space?
Any input would be appreciated, I have searched the forum and the reference page but I am not sure how to start.
Cheers!
John
To get the first digit, you just divide by 1000, because 2955/1000 = 2 in integer division.
You then subtract 2 * 1000 from the original number, to give you 955.
Divide this by 100 to get the second digit, 9
subtract 9 * 100 to give you 55.
Divide by 10 to give you the third digit
pixle:
SO, my question is:
Your thinking is correct. Except the direction.
It is easy to process the digits one by one from the rightmost digit to the left.
  int temp=2955;
  int digitFromRight=0;
  while (temp>0)
    digitFromRight++;
    Serial.print(digitFromRight);
    Serial.print(". digit from right is ");
    Serial.println(temp%10); // <--- this is the digit
    temp/=10;
Thank you both for your answers. I'll get my hands dirty with code asap :grinning:
